P1000 Electrical help
Dordon
Dordon
38
123
Eastern Kentucky
Hello everyone, I know this has been discussed many times but the more I read the more confused I get, I am electrically challenged but am trying to learn. I had a dealer add a dual battery to my P1K but I noticed they did not add the True isolator just the stinger and attached the winch to my secondary battery, is that ok? Also I will be adding a switch panel from PBR with 6 switches, usb, dual volt meter, and a 3" Boss radio receiver. I have a Blue Sea Fuse block to puck it into. My question is what's the best screws to hold the plate and I know I need to daisy chain the accessories but I am not sure how to hookup the the accessories to the fuse block. Can someone help me with a picture of layout easy for me to understand. Thanks
Scoop
Scoop
4,271
16,003
  3. Talon R LV
If you have a second battery but no isolator, then you have two batteries connected in parallel. While that will definitely be an improvement over a single battery, you're missing half the reason for that second battery: Isolate the load of all your accessories to one battery and ensure you don't run your primary battery down, If you run the AUX battery down, having a full primary battery means you can still start the machine and the DCT transmission will still operate properly to get you home.
Honestly, adding the isolator now would not be a big deal. I suggest you watch @RobSparre's video on dual battery install first - should provide all you need to know (you'll just be adding/moving a couple of cables and installing the isolator). There are links to his wiring diagrams on the YT feed, too.
Scoop
Scoop
4,271
16,003
  3. Talon R LV
Agree with Scoop. Would go the true isolator route. Club store has them too. I’m running the true and have added a stinger too.
If you live in colder climates where stuff freezes, avoid the Stinger and go with something like a marine grade Cole Hersee relay.
Dordon
Dordon
38
123
Eastern Kentucky
Thank you everyone for all the help. I drew this diagram and was hoping to get some input as if it's done correctly, I have not added the winch yet to this and also do I need a volt meter relay between my dual volt meter or not? Thanks.
Screenshot 2
bumperm
bumperm
1,851
6,658
Gardnerville, NV
At first blush, looks reasonable. If using that 100 amp circuit breaker, it should go as close to the battery + as practicable on the feed side of the stinger relay. That way it is protecting wiring to stinger etc. (I didn't use a CB on my install.)
Buckslayr
141
353
Nd
Why colder climate problems with stinger
Reactions: TxDoc
Scoop
Scoop
4,271
16,003
  3. Talon R LV
Internal moisture will freeze up and it won't work.
