Talon Enclosed Trailer
SLOWPOKE693
SLOWPOKE693
1,597
6,047
Somewhere in Texas
Didn't know this thread existed. Here is my submission.....
2021 28' Continental Cargo Nitro. Picked it up a few months ago from Phil's Trailer Sales in Waco, TX. They had the best price (by alot) out of all the dealers i checked with in TX, OK and Arkansas. :cool:
20201115 165656
20201115 165733
20201111 130021
20201111 125959
11,313
84,048
Glad I got the 8x18, extra tall, easy to walk around and stand up to strap the P500 and atv down. MPG suffers but what’s a few dollars when you get what you want. For a wider SxS, seems climbing out would be a PITA. P500 is 54” wide. Plus color scheme matched the truck.
B25D77B9 E46F 4004 B151 52FB6F832CB1 B6691ED2 87B1 46CC 84A1 DD0B66465EBF
N
Nilak71
0
Canada
I have a 7.5 x 14 Stealth aluminum enclosed trailer for my Talon X works just fine.
TalonMatt
TalonMatt
64
128
WA
I've been spending some time organizing before we go racing. I highly recommend Pit Pal products if you are in need of trailer storage ideas. They make some cool stuff!
View attachment 250565View attachment 250569View attachment 250566View attachment 250568View attachment 250567
I like the jack holder! I just have mine strapped up.
AFE48BED BD12 475D B0B1 F91AB54ED5E1
SLOWPOKE693
SLOWPOKE693
1,597
6,047
Somewhere in Texas
You guys think I'm kidding! This started out as a bone stock KLX110 that I bought to "mess around on" when I got out of full size MX racing. The only thing left of the original bike I bought when it was done were the engine cases. And even those were highly modified........
101 0083
101 0069 1
101 0071 1
As you can see....... I have a problem! 🤣
F
Fun42
Look trailers builds a 7.5’ trailer with a extended V nose from 24” to 30”. They will place the walk door on the drivers side of the trailer. If you move it back to just in front of the wheel well and pull your sxs forward so the two doors line up. The door to the sxs will open up in the open door to the trailer.
Might want to some of the othe Mfg. I work with Look trailers.
Reactions: Smitty335 and CID
208,011
HA! I did that to an old IT 175, Fabricated a second chain tensioner, issue solved.
Brazula4life
73
91
Florida
I've always towed SxS in an open trailer. Looking at going to an enclosed trailer but really don't want to go with a 8.5 foot wide version. How difficult will it be to get in and out of a Talon X inside a 7 foot wide trailer?
Thanks!
I'm 6,2 260lbs if I can manage to get out from a 7x16x7 than I dont think its that hard. Main part to pay attention its the ramp wires I only have about 2 inches on each side. A 8.5 would be nice but a 7 does the job just fine. Pick it up few days ago.
20210302 173457
Reactions: Coeus and TimG
bjniceguy
322
431
Iowa
if you go back in this, you will see optional side door on drivers side to get out of 7' wide trailer. Also if you don't have that option, you can park on slope & use winch to pull talon in & let it roll out (can push if ground is level). Not best choice, but a choice
Reactions: TimG
TerryH
TerryH
664
2,241
Springdale, Ar
When we had our 7x16 I removed the wire from right side. Adjusted the other a bit tighter and never had any problem with it. Way easier with just the one wire.
Reactions: TimG
Brazula4life
73
91
Florida
I assume you removed the wire with the door closed, but even then isn't the wire under lots of tension?
Reactions: TimG
