G
I need some assistance in determining where to start diagnosing my problem. Here's the situation: Rode about two weeks ago with no issues and no issues prior to that ride. I cleaned up the machine and parked it for a couple weeks. Ran it a couple times in those two weeks but just to move around the garage. No issues. Took it out for a ride and filled up with ethanol free fuel on the way. Within a mile of riding it started stumbling while at speed and would go dead at times when I stopped. After it died, sometimes it would take several seconds of turning over before starting, sometimes it would start right back up. At times it would cut out at speed for a couple seconds and then start back before coming to a complete stop. I'm not getting any check engine codes. I'm thinking bad gas but want other's thoughts. Specifically, could it be the injector wire with no codes? Would you start by siphoning out the fuel and filling with fresh to see if that fixes the issue? (Is siphoning the best way to empty the fuel tank?)
Here is some info about my Pioneer:
- 2018 1000-5 with about 300 miles
- Dual battery setup with isolator. NOTE: I did add a wired remote for my winch since the last ride but I only touched the electrical on the dual battery side.
- Fuel tank vent line extended up to roof line so I don't think water got into tank when I washed.
