![Redmoon](/data/avatars/m/16/16398.jpg?1552704185)
Thanks Smitty just did that. It will get a good test next weekYea, but you need a windshield, go to the under the seat the fan route, I tried every thing, the fan works!
HA! Where you live?i have boom mat under my seats and bbq mat on the seat back.full windshield,mid panel and bimini roof and little to no steam from blasting water holes,heat is minimal.
The insulation package isn't a waste, it blocks the steam, but the fan takes care of most of the heat.Thanks Smitty just did that. It will get a good test next week
Thanks for clarifying! My brain was melting lol! I ran automotive heat shield from the front of my seat base all the way up to the top of the seat-back in one piece. Had to remove seat belt bolts and reinstall them after shield was in place. Only holes are slits for seat belts and 5 seat-back bolts. The heat in mine is no longer enough to bother me. Maybe try removing your engine shroud. Seems counterintuitive but others have said it helps. (I removed mine at the same time that I added my shield so I don't if it's the shield or the shroud removal or both, but it's not uncomfortable anymore). Used in south Louisiana heat + drowning humidity!!!Read: in Alpine AZ next week. I hate when my phone thinks that it’s smarter than me
I just noticed you have a gel foam cushion. I'd remove that immediately! Those things hold heat like a baked potato!Now I get it, or where you were heading anyway. I only have a half windshield here in Az. So air flow is not a concern. What bothers me is having to wear asbestos underwear to go on a long ride.
I have automotive heat shield under the seat and up the back of the seat. I have a gel foam cushion on top of my seat and in 90 deg. AZ heat it gets much warmer than I would like. Which is why last week I finally got around and installed a WALMART fan. Go Walmart! Gawd such BS.
does it get hot and humid where i live? yes,it does.HA! Where you live?
Anyone have a pic of the installed walmart fan I'm in North east TX gets hot here also with humidity.... No offense to AZ folks
Can someone post a picture of the installed fan with instructions for those of us who are a little challenged when it comes to something like this? Thanks.Yep to the heat, skip all the insulation packages, copied @JTW and hung a fan under the seat, heat in the winter a very little in the summer .
I wouldn't have a clue on a P5.Ca
