P1000 Evap system
zfisher
zfisher
Marion Iowa
I went to extend my fuel vent lines yesterday to discover that my vent line leads into the evap recovery system. I wondered why I got a good deal on my machine. Everything else about it is fine question is, since the evap leads back into the motor do I really have a need to try to extend anything? Once I saw that I pretty much just put the seat back on and went inside not very happy. Any feedback would be appreciated thanks!
MVIMG 20200729 162414
drumstick
drumstick
10
Orlando
I just ran into the same situation. I think that whole system can be deleted - if you unplug it there are no codes. How did you move forward?
115,793
Thread is 3yrs old no post since, he hasn't been on in bit as well.
To help with ur question, what u said will work .
drumstick
drumstick
10
Orlando
I was hoping it would spark some memory - guess I should have started a new thread asking the identical question.
To delete do you just cap the vent tubes?
drumstick
drumstick
10
Orlando
This one was sold in Florida - but it has the lower weight rating and the evap system so I would assume its a CA model. The Evap is right in the way of where I want to mount an underseat fan to help with the heat.
JenElio
JenElio
73,471
668,124
Loxahatchee, florida
Yeah that's the Cali model. You should be able to bypass all that nonsense
JenElio
JenElio
73,471
668,124
When I snorkeled I T'd off of the tank vent and ran it up the roll cage already.
There's about 5 or 6 vents you want to extend if you ride like we do down here. We have a lot of water compared to some other places up north. You know even if you're not planning on it, water can get deep REAL quick 😬. I'd look into deleting all that EVAP crap and vent everything up higher.
G
GolfCart
141
404
NH
Front Diff, Fan, Sub-Transmisson, Fuel Tank, Rear Diff, Rear Diff Cable Box
208,726
Have you ever considered a boat with a jet drive motor?
zfisher
zfisher
Marion Iowa
It's been awhile since I've been on here, I've just left it as it is for the last 3 years and haven't had any problems, I went back and put better clamps on all the connections, I don't go through deep water either. I haven't had any issues with the system it's self yet....
Reactions: Robobrainiac
