P500 Exhaust is on the way
ehart814
ehart814
1,654
3,644
NWPA
I just got home so I could finally watch your video. That is awesome!!!!! I love the sound! Were you lifting when you were shifting or just holding it to the floor? Definitely seems snappy. Thank you so much for this post!
Skullmonkey
Skullmonkey
26
31
Southern Ohio
Screenshot 2016 05 19 10 37 44
Just making sure this is the one you bought before I order it?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
also you will have to cut off the old exhaust hangers and weld one on lower ill see if I can get a close up shot of how I have it
Skullmonkey
Skullmonkey
26
31
Southern Ohio
I was just getting ready to ask about the hangers. So you pretty much put the new hanger where it needed to be so that the pipes would line up?
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
your old exhaust cut off right at the welds for the cat also on the hmf cut off JUST the part where its reduced and it will match right up
Reactions: Talen and ehart814
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
yes I bolted the rubber bushing to the silencer reused the hanger I cut off connected it to the other end of the bushing then welded it to the frame
Skullmonkey
Skullmonkey
26
31
Southern Ohio
I'm not too shabby with a welder lol. I'll be watching for when you get the AFR controller, I'd say before it's all said an done I'll tear this thing down an big bore it lol.
Reactions: ehart814
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
ive been looking into that to hahahah even a high compression piston
Skullmonkey
Skullmonkey
26
31
Southern Ohio
I don't see why a big bore kit for the 500 atv's wouldn't fit lol. Idc about top speed I just need a little more power, 3rd gear just ain't got it for going through a big mud hole an there's just not enough momentum in 2nd lol
Reactions: ehart814
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
try it after the exhaust it gets rid of the 3rd gear low bogging I haven't tried mud yet but on turns and hills where id have to down shift to 2nd I don't now
Reactions: Montecresto
Skullmonkey
Skullmonkey
26
31
Southern Ohio
I could see the cat really holding back. I'd say if you just cut it out an left the stock muffler you'd notice a big difference
Reactions: ehart814
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
yea but even the stock muffler is just a little pea shooter lol
34,175
True enough, but then you loose the spark arrester, a must on BLM/NFS trails. Though that's not likely an issue in southern Ohio.
ehart814
ehart814
1,654
3,644
NWPA
Actually, I believe the spark arrestor is located at the back end of the muffler. Ever noticed the plug on the bottom of the muffler? Periodically you're supposed to remove that plug and rev the engine. This cleans the carbon out of the spark arrestor. I don't believe gutting the cat would have any effect on the function of the spark arrestor, but I suppose I could be wrong.
34,175
Or I could be, it's just what I was told here when I asked about it!!
ehart814
ehart814
1,654
3,644
NWPA
I contacted Supertrapp about making an exhaust. They are not going to do one for the Pioneer 500. They recommended their universal mufflers.
