hi guys,
New here. Looking at getting a P500 this spring and planning on 30" tires on 12" beadlocks with more offset to keep some stability with the bigger tires.
Rode a P500 for the first time last week and was very impressed with the stability in stock form.
The reason for 30´s is because our trails are very rough with lots of rocks. My Rhino on 27" Mudlites did ok however I want more ground clearance and a smoother ride that I feel can be accomplished with big tires running low air pressures.
Does anyone make fender flares for the P500? I assume with any offset I will be getting mudy amd would like to avoid it if possible.
Thanks!
Thanks!
