P1000 Fox shock users.. settings?
nitzo
nitzo
521
1,106
East Coast, Florida
2.5” front and 1.25” in rear is where mine sits level and has good ride. Can go more and get more lift but wife doesn’t like jumping up into Pioneer. Run soft on front and medium on rear and increase rear to hard if it’s fully loaded to stop bottoming out
Here's my shocks, can you describe where you are taking these measurements from? Thanks.
Shocks
Reactions: TimG
aauman88
aauman88
1,091
2,846
The shock body is the threaded part(grey). The shock cap is top part(black). The adjusting nut is black ring that you adjust for preload.
The gap between bottom of shock cap and top of adjusting nut.
B14D285F 67F8 48F7 BF31 4E0E97ACA18E
Reactions: nitzo and TimG
nitzo
nitzo
521
1,106
East Coast, Florida
Awesome, and u went 2.5 in the front and 1.25 in the rear. Thanks, that helps a lot .
Reactions: TimG
TimG
TimG
OLD SKOOL
795
4,008
Southern Indiana
I got my shocks today and looking forwards to getting them on. Do I need a spanner wrench for the shock pre load adjustment or can I get by with out one ?
aauman88
aauman88
1,091
2,846
no problem. That is my sweet spot with my setup. Yours May be different but that’s a good starting point
aauman88
aauman88
1,091
2,846
Sure you could do it with big pair of channel locks but would scar up the nut pretty good. I’d invest in a spanner wrench, they are cheap
Reactions: TimG
TimG
TimG
OLD SKOOL
795
4,008
Southern Indiana
That's what I figured, I'll order one tonight.
Reactions: JTW
TripleB
TripleB
21,011
183,015
Caryville, Tennessee
Also dont be dumbass like me and put the rear shocks on the wrong sides. Make sure the reservoir is turned toward the front. I had mine wrong for a couple of rides and it pinched my brake lines almost into.
Reactions: Plumber32 and TimG
TimG
TimG
OLD SKOOL
795
4,008
Southern Indiana
Also dont be dumbass like me and put the rear shocks on the wrong sides. Make sure the reservoir is turned toward the front. I had my wrong for a couple of rides and it pinched my break lines almost into.
Thanks I appreciate it ! I had already ordered an adjustable spanner wrench and a set of 2 non adjustable ones just for s***z and giggles :)
63,071
Definitely adjust them before putting them on the machine if you can. We did mine on the machine and even with good spanners had to use a punch to get the retaining ring loose on both sides. I left the stock front settings but needed to add about 1.5" of preload in the rear to get back to the ride height I had previously on my P1k-5.
Reactions: TimG
TimG
TimG
OLD SKOOL
795
4,008
Southern Indiana
Thanks for the tip ! I can see that would be a bear when mounted. I will try to get them close before mounting.
Reactions: nitzo and Adam490
