P1000 Fox shocks
nbomar
nbomar
4,416
17,854
Springdale, AR
I was hoping to do that last Saturday, you got every thing straightened out?
Be2729251369a881d2390c028bee242fFea46d6f2d55339e322e85ddc15bf0f3
Thanks to @CumminsPusher for some tips. Headed to get anti seize and spray foam for the doors now.
208,730
You must have hit pretty hard, are you setting toe in on alinement, I set mine at 1/16, 1/32 on each side, I haven't driven it on payvecet or flat dirt roads yet, I like it on trails.
Reactions: CumminsPusher
208,730
How about lunch?
nbomar
nbomar
4,416
17,854
Springdale, AR
Haven't done the alignment yet. Do you just measure front and back of the tires?
322,675
Yes. Approximately 1/4in in at the front.
Reactions: dotman1
322,675
I think that is @JTW's number......Should keep him busy for awhile.......;)
I would be still chuckling by morning it that were so!
Reactions: popeye and JTW
208,730
For a quickie I use two jack stands and a string, set them up front and rear on one side,set the jack stand about 2 inches off wheel move the front jack stand to the same measurement from back of the back rim to front of back rim, that will be pretty close to being in alinement with the back wheels and then set what ever alinement you want. measure the back of the front and compare to the front of the rim measurement to the back of the rim measurement. Be sure to tie your steering wheel .
nbomar
nbomar
4,416
17,854
Springdale, AR
I didn't do all that but it looks pretty straight and I bounced it around in the driveway to let it settle. "Good enough"
208,730
It dosen't take long
Reactions: nbomar
