P1000 Front Lightbar Relay Wiring Diagram
bmcote
bmcote
54
226
Colchester, CT
Hi All! I needed a gut check on the attached wiring diagram. I based it on other posts and @RobSparre diagrams.
  1. The relay is from the light bar setup (Amazon.com: LED Light Bar 52 Inch Curved AUTO Work Light 4D 500W with 8ft Wiring Harness, 50000LM Offroad Driving Fog Lamp Marine Boating Light IP68 Waterproof Spot & Flood Combo Beam Light Bar: Automotive)
  2. Switch is a OTRATTW lower independent (High quality OTRATTW Contura V laser-etched lower independent LED rocker switches).
My plan is to chuck the harness that came with it (which included an on/off switch) and doing my own wiring for neatness.
Does this look correct to y'all???? (the numbers on the wires indicate gauge for my own edification)
The relay is in the picture on the left for reference...
Jlpp8GfWS82pcgEB9xmx3g
bmcote
bmcote
54
226
Colchester, CT
thank you @Hondasxs ! as always super helpful. i have all the switches daisy-chained together (both ground and hot) for the switch lamps, so those are on a separate ground line already.
while i have you here, i wanted to gut check my other diagram. this one is for my lights without relays. does this look correct also? same otrattw lower independent switches...
ZOmJsrIkT2mwy ukmMkJdg
67,230
Ya.
But no need for 2 + lines here.
Jump pin 2 to 6.
Unless your controlling the backlight independently .
Also. If these switches are beside each other. You can jump 7&8 from this switch to the 7&8 on the other switch.
