P500 Fuel Controller, Exhaust for the P500
JCart
JCart
895
2,021
Kamloops, BC Canada.
Hey Guys,
Have been trading Dillon at Dobeck Performance e-mails in regards to development of a fuel controller. Also questioned him about an exhaust as well, as I've not seen much for the P5. Latest word as of today he (Dillon) thought they'd have something pretty soon along with two exhaust options. Hmf and Big Gun is what he mentioned.
So for those that have a fuel controller, exhaust and performance filter on an EFI Honda ATV, or dirt bike I'd like to hear your thoughts.
Will let you guys know when Dobeck has a P/N for parts.
Cheers
jrc
Reactions: sthomp54
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
I run the dobeck with fmf and uni filter on my crf and its amazing also I run the dobeck with hmf and uni filter on my 420 rancher and they completely transform the machines instant throttle response and much better power delivery
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Hey Guys,
Cheers
jrc
ive been told for almost a year that they have been close to finalizing them lol
JCart
JCart
895
2,021
Thanks jak99... Pleased to hear this, I hope Dobeck gets something out soon. I know it's been about a year since I first contacted Dillon (at Dobeck) about P5 controller and they have released one for the P700, just this last fall I think, least they list a Part Number on their site.
I looked at HMF's and Big Gun's sites, and they don't list a P/N for exhausts for the P5. Hopefully they will show something soon. Dillon did mentioned these two Co's had/ where doing something and im thinking it would be just a matter of developing mounts as the muffler for a 500 cc engine has been done (other applications) for years.
jrc
Deleted member 3748
like big foot ill belive it when I see it
BFretro1
How is this installed?
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
install is cake swap out 02 sensor install bypass on old 02 harness then just plug the wires in and go
oly1981
oly1981
Lewiston Idaho
Guessing just like a dirt bike, unplug cable to injector and plug that into controller and controller plugs into injector. The question I have is if it use the same location for the O2 sensor? I think on the 700 kit it uses the wide band O2, not sure if you would have to weld a different bung in the header.
That wouldn't be cool. I looked at the link for it above and it shows no instructions that I could find.
oly1981
oly1981
Lewiston Idaho
It wasn't that big of a deal on a dirt bike, pretty easy to weld in or have some one do. Hopefully it will be the same location.
Jak9922 didn't say anything about welding, hopefully he's right. In any case, I'll not be doing it until I get feed back from others who have.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
you have to remove your factory 02 sensor and hope the new one fits if not you have to weld in a new bung
Why would AFR+ manufacture a product for the P-500 that doesn't fit the P-500???
JCart
JCart
895
2,021
Looks like Dobeck has one on their site for the 500! Who going to pony up and buy one? I've got one on my kx450, seems to wake it up and is better on fuel.
AFR+ - Air/Fuel Ratio gauge plus EFI controller. #1 Fuel trimming and closed loop controller.
Nice oly1981.... Thanks, not made time to look at their site. Dillon from Dobeck did mention that a stage 1 kit was being developed and that included (I think) aftermarket exhaust, fuel controller and air filter. I think P5 exhausts are all one piece, so will be interesting to see what HMF and Big Gun come up with. Presuming entire exhaust will be replaced from cylinder exhaust port to and including muffler? I trust the O2 sensor bung will be integral on their respective pipes? Guess the other option maybe to trim off everything down flow just infront of O2 sensor and replace with slip on system, I don't think there is room between stock O2 and Cat to cut and clamp slip on system although I could be wrong.
jrc
Reactions: oly1981
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
Guess the other option maybe to trim off everything down flow just infront of O2 sensor and replace with slip on system.
that's what I will be doing if they don't come out with one soon lol I have a stock cbr pipe begging to get used on something
