P700 Fuel Gauge Quit
William
William
1,442
2,887
Flowood MS
Well my p700 ran out of gas today and was still showing full... I filled it up and reset the trip. How do I fix it?
Reactions: Mudwing and Russ989
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
your sending unit is either stuck or out. i seen a post about this a few months ago.
Russ989
Russ989
22,569
146,535
I’ll look in my shop manual when I get home.
Reactions: Mudwing and William
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
me either really id imagine the top of the rank with the fuel pump like a car. but iv never researched it
William
William
1,442
2,887
Flowood MS
Maybe the float is stuck?
That’s what I have been reading about. I’m hoping it will dislodge... I really don’t have time to mess with it till after hunting season. I beat on the tank a little, maybe it will help... I will probably take the fuel pump out next spring and have a look if it’s still acting up.
Mudwing
Mudwing
36,959
306,563
The Mud holes
Sounds like a plan. ;)
NTCPrezJB
NTCPrezJB
President of #NTC
100,629
899,200
Canton, OH
I guess if something has to go wrong that isn’t the worst thing. Hopefully it wasn’t a long walk to more fuel.
Farmer
Farmer
2,851
16,389
Southern MO
I remember hearing something about the tank inerds rusting up if you don't keep them full. Anyone got the link?
William
William
1,442
2,887
Flowood MS
Mine usually stays full. I don’t put a ton of miles on it. I would hope it’s not rusted!
Reactions: Farmer
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
i dont think is that cause mines rarely full.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
maybe carry a can and let it get low and bounce around. if its stuck might bounce loose during hunting season
Reactions: Marketgarden
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
i am almost always just a little below half after a ride now before the portals i was low fuel light basically till the next ride
Reactions: Farmer
William
William
1,442
2,887
Flowood MS
FYI I removed the fuel pump today and reinstalled it and the fuel gauge started working again. Float was just stuck on the side of the tank. Do not buy either tool Honda recommends for the fuel line or the lock ring, they are not needed. On fuel line I gently used pliers to squeeze the collar and remove. On fuel tank lock ring I used a large screw driver and rubber mallet to tap it and make it turn. Simple job...
Buggyman
Buggyman
34,183
292,629
ne. ohio
hello William I was wondering if when you took out your fuel pump unit because the float was stuck if you happen to remember which part of the tank it was stuck on front ,back,driver side, or passenger side. mine is only reading 4 bars when it's full to the neck. don't think mine will b as easy because of the cab.THANK YOU.
William
William
1,442
2,887
Flowood MS
The float faces the rear of the bike...
Reactions: Buggyman
