P1000 Fuel pump voltage?
I
infernored1000
219
262
Anybody know what the fuel pump voltage is? Asking for a friend lol got some bad gas and had to drain tank, cleaned up everything just want to purge the fuel pump with clean gas before putting it back in
66,870
If you dont unplug it... Looks like your fan may come on with it.
Someguy
181
179
Krakow Wi.
What ever the voltage of the vehicle he is working on is. Pretty much everything is 12v
Mopower58
Mopower58
Unburdened by what has been!
79,849
709,081
Crystal Springs,Ms.
Won't the fuel pump run continuously with the key switched on?
Mopower58
Mopower58
79,849
709,081
Crystal Springs,Ms.
Did you get it resolved? If the fuel tank has been cleaned why not install the fuel pump,disconnect the fuel line,hook up the factory wiring and purge that way?
I
infernored1000
219
262
Just went ahead and ordered a new fuel filter to be on the safe side
I
infernored1000
219
262
As many have said on here before about the vent lines being in terrible locations I absolutely agree especially the gas tank vent line. Since the tank is off already gonna go ahead and extend all vent lines
