P1000 Fuel tank accuracy
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
First fill up.
Fuel guage was at the bottom, and blinking (okay... maybe it was only blinking when on a slope) regardless, it was on the last bar.
6 gallons filled it.
So I have 2.7 gal when it shows empty? :)
0
0860silverado
945
1,813
louisiana
First fill up.
Fuel capacity is 7.9 gals so you'd have 1.9 gals left when yours shows empty. But yeah...the fuel gauge on these units tend to be very forgiving on accidentally running out of fuel. If you actually run out, you've probably been riding on "E" for hours!
Reactions: BWAF and Mudwing
mjn
mjn
1,409
5,206
Ah.. okay. 7.9 gallons. For some reason I had 8.9 in my head. That does make more sense.
How many trail miles does the average rider get out of a tankful?
ofrcboy
ofrcboy
501
572
Oregon
Never had mine blink, but hate ridding with one bar showing. Thanks for the info.
Reactions: BWAF
TheHoover
TheHoover
221
693
PNW
hondasxs.com
First ride on dirt with her. 45 miles. One bar over 1/2 full still in tank. We should of took the long loop! Lol.
FE46F623 0F1A 49F7 B43C 8926833607BB 782CE6A4 4129 4B32 9FFA CBF662CAE3FC D289A5EC 36C8 4DA4 9B6F DE3B87BBB5FF 762BE940 2F24 4A85 BCB3 B84B18381406 5BF0B113 95E3 4FC5 BDAB 9E8D8288AECE
208,011
Reactions: BWAF
0
0860silverado
945
1,813
louisiana
Miles per tankful on trails is almost impossible to quantify. Hours per tankful is what I go by and slow trail riding burns in the ballpark of .75 gallons per hour (depending on the trail). So... 7 gallons should fuel your rig for over 9 hours of trail riding plus a little allowance for margin of error. (Hours per tankful fall drastically if used at high speeds).
Reactions: BWAF and mjn
208,011
Miles per tankful on trails is almost impossible to quantify. Hours per tankful is what I go by and slow trail riding burns in the ballpark of .75 gallons per hour (depending on the trail). So... 7 gallons should fuel your rig for over 12 hours of trail riding with a little allowance for margin of error. (Hours per tankful fall drastically if used at high speeds).
Doing yard work for a week seems to burn more gas than a day of trail riding
mjn
mjn
1,409
5,206
Yea, I found that to be true with my Yamaha as well.
I never checked to make sure the dealer completely filled the tank, but my odo said 55 miles when it took 6 gallons. All of that use has been on my 9 acres here.. changing water, running up to get the mail/paper etc.. plenty of sitting at idle too. I'm guessing it would do 100+ trail miles on a tank.
There is a comparison vid out there with the X4, and the Teryx.. they said the Pioneer burned the least amount of fuel.
Reactions: BWAF
208,011
My wife was so mad at me when I pulled up in the drive way with Rooster, then we started using it for yard work, now when I leave for work, the last thing she asks me is, where are the keys for Rooster. HA!
Reactions: mjn and BWAF
mjn
mjn
1,409
5,206
Oh, I can relate to that.. even when we had the Yamaha, it went from living in my shop, to taking a spot in the garage.. She gets off work far earlier than I do, she'll take the Shepherd and the Pit & go change water or just ride around the pasture..
Reactions: BWAF
Z
Zmorris83
I've had mine since the end of July. ~3000 miles. 201 hours. The worst mileage I've seen is 21mpg with an average speed around 13. That was from a 5 day 312 mile ride in the mountains of Arkansas but I don't remember which day. 46, 67, 81, 48, & 70 mile days logged on Maprika. It was probably the 48 mile day. I was riding with a RZR 1000-4 turbo and a 900 Ranger who were burning 4 to 7 gallons a day. Double, or more, the fuel consumption as my P1000-5. The Ranger owner was proud of 46 mile 4 gallon refuel. He was heartbroken when I filled up with 4.2 on the third day at 113 miles which is the best MPG I've ever calculated. I usually see 24mpg around the house on gravel/sand. I know it would get better if I didn't have it loaded down constantly, tried for max mpg and stayed on paved roads. Back when it was REALLY new, and all I wanted to do was ride, my son and I road over 200 miles in one day, on one tank, in 8 hours (plus 2 hours of fishing). Wish I would have taken an odometer picture before and after to know exactly what MPG it got. The factory tank will definitely hold more than 7.9 gallons BTW. I also have a 2 gallon fuel can under the driver seat that I've never needed.
OnTheJob
OnTheJob
426
925
Bristol, NY
I get down to 2 bars and I can't get a whole 5 gallon jug in it to fill it back up.
Reactions: BWAF
