Talon Gauge Relocated
bjniceguy
322
431
Iowa
Idiot
Am I understanding you correctly that if you remove some of the tape on the harness, that I can leave stock gauges in slots they are in now?
IDIOT
IDIOT
280
755
Kingman, Az.
Idiot, I have been looking at this after NVBlu told me about a friend getting it. So I just want to confirm you don't have to relocate the switches?
I want to but a bigger gps screen in that spot if I can.
As long as you pull the tape off the harness and then you can spread the wires and you will not have to move the switches.
IDIOT
IDIOT
280
755
Kingman, Az.
YES Exactly
If you remove the black sheathing and tape from the harness that has all the wires that go to the individual switches you will then be able to untangle and spread those wire out enough so that you will not have to remove and swap the location of the I4WD and AT/MT switches. It is worth the effort and you will be Very Happy with the new location of the gauges.
bjniceguy
322
431
Iowa
thanks i ordered it yesterday along with the tender springs
Reactions: IDIOT
HavasuDave
HavasuDave
164
307
Arizona
Thanks, oh forgot to ask, how much do you need to take apart? Are the instructions sufficiently clear?
HavasuDave
HavasuDave
164
307
Arizona
IDIOT
IDIOT
280
755
Kingman, Az.
On a separate topic, please tell me about your GPS and what maps you are using. That might be just the thing to go in the old display hole. Does it show the trails and what type of land you are on?
No that is just a Garmin unit and it just shows dirt roads and large well beatn trails, and leaves bread crumbs every where you go to find your way back out. I have a tablet mounted above my head that is loaded with Gaia map software for navigation.
Reactions: HavasuDave
IDIOT
IDIOT
280
755
Kingman, Az.
You just have to remove the hood and the piece right behind the hood right where the bottom of your windshield would sit, and the rubber curtain that hides every thing.
Moto4
46
51
Vermont
Not too bad, just removing the 2 little phillips screws without dropping them that hold the gauge in its original spot.
I started my installation today. Took the hood and the piece behind the hood off. Having a hard time seeing how to get the gauge out. Got any pointers?
IDIOT
IDIOT
280
755
Kingman, Az.
If you look up in there behind the gauge you will see a couple of small phillip screws, just remove those.
TalonMatt
TalonMatt
74
156
WA
I helped install one on my buddy's Talon. Even at higher cost, I think they would be better to make a matching extension harness to feed the pod, instead of the rest of that monkey business.
D114BC08 537E 44E3 86F3 76A54FB4A027
Reactions: 1HasBeen
nm6r
nm6r
78
173
Sandia Park, NM
There are three phillips screws holding the assembly in place, one at the bottom and one on each side at the top. The top screws are a little hard to see. Get onto the top screws from below the frame bar for the right angle.
Reactions: IDIOT
bjniceguy
322
431
Iowa
so the wire extension is just for auxiliary plug and not the gauge right?
nm6r
nm6r
78
173
Sandia Park, NM
I never figured out what the supplied wire extension was for so I didn't use it. I also never figured out why it was required to unplug the 12v. accessory plug and switches so I didn't. I also didn't reverse the position of switches or slice the boot and use silicone sealant.
I opened the harness at the "tee" by removing the black tape and opening the sheathing almost to the gauge cluster connector. I extended the two wires going from the gauge cluster connector to the termination connector by 22" then put the sheathing back on and black taped the "tee". This allowed the wiring harness routing to remain original except for the portion going to the gauge cluster.
Moto4
46
51
Vermont
Attacked mine this weekend. A pain in the neck process. Thanks Mn6r for helping me find the screws. Since I was adding some USB & DC outlets, and mounting a GPS, I decided to un-fasten my dash and tilt it up to get better access (6 million screws & rivets). I un-taped most of the harness and used the supplied extension cable to extend the 12 volt accessory plug. After doing this I was able to route the gauge connector to the new location without swapping the switches. I wasted a lot of time figuring out how to unplug the connectors. Does anyone know if this is covered in the Honda Shop Manual? The new gauge position is so much better plus it allowed me to locate the GPS where I wanted to.
Tramguage1
Tramguage1
Texan
7,576
31,279
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
think this mod is on my short list!
Reactions: nm6r
