P700 Gear swap
MntGoat
39
Maine
I don't usually ride with anyone, I use it around camp and we go exploring. For the times I have rode with others, I've had zero issues keeping pace.
MntGoat
39
Maine
I ordered an ecu from a 2014 model. Will post results when I install it. Hoping the electrical plugs are the same. I know I will lose the o2 sensor but if it all works correctly, who cares.
I got the ecu used for $70 all in so I figured it was worth the chance.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
question. when you unplugged the sensor it wouldnt shift out of first? wonder if your switched the sensor and once if got into 3rd flipped it off if it break the 44 mark. only down side is hope it wouldnt try to downshift to first. 1 other thing is which i havent looked at is maybe checking the speed sensor gearing see if its changeable.. kinda like changing speed sensors on old trucks to right the speedo back before the computer days
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
SpeedoDRD
check this thing out. a few of the 500 guys used it to clock there sensor and get few more mph out after regear. basically you could make the dash read 40 when your doing 50 on gps
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Gotta read the whole story to get the whole gain!
so its 2014 pioneer ecu . or rincon ecu?
because if im thinking right. and its a 2014 pinny ecu. then that means the 2014 and below are rev limiters instead of speed limiters. which would explain the variances in top end speed in the early models
MntGoat
39
Maine
I don't mean to make a generalization but I will. I've noticed on the Facebook pioneer forums no one reads what you wrote, they just want answers.
I'm all for helping but use some sense here. I never said it came from a rincon.
Reactions: MBeaulieu and KyleC
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
lol im not even on the facebook one. but alot of people do that.
iv read this whole thing a few times and been following was curious. and now i have even more curiousity about the speed limiter for certain models. lol
rincon gears plus 2014 pinny ecu means early pinnys were rev limited instead of speed limited.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Yep, I did read it. Just didn't ask enough in my question. So the install of the taller gears didn't have the results you wanted until you installed the 2014 ecu. I didn't mean to sound like I didn't read the whole thread. I have been following this from your first post. Seriously thinking about doing this mod, just a little worried about the loss of low end torque. Thanks for your time.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
if your a trail\road runner and running stock sized or a little over youd be fine. but if you mud. i wouldnt recommend it. im at stock gear with 27s and thats all she wants in 4 lock and can still get to speed limiter. i dont think id even be able to hit 55 with my 27s on it unless i was WOT and going downhill.
Reactions: Mudwing
MntGoat
39
Maine
Just the gears gained no more top speed, just s lower cruising rpm which is nice if you are traveling st speed. The 2014 pioneer ecu uses rpm to limit speed so by using that you can run a higher top speed.
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
Thank you
Reactions: MntGoat
jchigg2000
Kansas
Can someone link the specific gear set I need to do the same thing to my 2020 Pioneer 700-4?
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
@BobRack this is it
Cyberjunk
Cyberjunk
Berserker
1,622
6,078
Crane Hill Alabama
Still like to see someone put 500 ring and pinion in a 700. Looks like it will work and gives a 15% gear reduction.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
18% about 5 said they have on fb but no pics
Reactions: Mudwing
