P1000 hard shifting on my 2020- not what you think
steve_whiteside
55
108
San Diego
  2. Other Brand
Gents, I have a 2020 1000-5dlx with 900 miles on it. From new the shift mechanism worked hard. Not the transmission jerking between shifts rather the shift lever going though the gates was very hard to get it to mechanically slide from one portion to another. I mentioned it when it was new and everyone (here) chimed in that give it some miles and it gets a lot smoother. It is still under it's 1 year warrantee. Still not better. It is pain to take the buggy to the dealer but I can if I have to. Any ideas?
Steve
Reactions: Plumber32
66,108
Steve
Theres cable adjustments next to where you check the oil. Under the floor board. A couple screws reveals the box. Had mine full of mud and water .
56,508
That's for 2wd/turf. Sounds like he might need to adjust the cables that are located behind the battery for the main drive modes.
0
0860silverado
945
1,813
louisiana
To help troubleshoot, try moving the shifter with the engine off. If it's easier with the engine off, you need a clutch relearn procedure done. If it's still hard to move, you likely have a cable pinched somewhere. Do you have any accessories installed? I seem to recall another member having his shift cable caught in some accessory mounting hardware.
Reactions: TripleB
steve_whiteside
55
108
San Diego
  2. Other Brand
I will try that shifting with engine off. The only accessory I have is a winch I installed. Im not remembering any cables that were jammed when I installed the winch- I think it was pretty easy.
steve_whiteside
55
108
San Diego
  2. Other Brand
So, I was on travel but just back. Interesting enough the buggy shifts just fine with engine off. Does that mean just a clutch re-learn procedure? I will google but is it pretty easy? Thanks again all of the help. Steve
The clutches will occasionally "stick" or be applied at idle speeds causing the gears in the sub trans to be under load with the engine running.
Same senario trying to shift a manual trans car into gear whithout depressing the clutch pedal. It will go but it won't be easy or smooth.
The relearn procedure allows the pcm to learn the pressures it needs to force the clutch to the engagement point.
This procedure almost always "unsticks" the clutch and makes shifting the sub trans much easier.
The only times I've seen it not fix the problem is if the clutch has been slipping and is already burnt.
Reactions: TripleB
@HondaTech does this procedure apply to the Talon also? 🤔
Yes, same procedure.
Our Service rep contends a clutch relearn should be done every time the vehicle is serviced. Since the clutch wears and the gap of engagement is different then when new.
It's second nature to me now, I dont even have to think about the sequence to trigger it.
Reactions: TripleB and CID
5,015
22,383
It's second nature to me now, I don't even have to think about the sequence to trigger it.
Thanks, Dude. :cool:
@Lil_Steve
Reactions: Lil_Steve
@Lil_Steve
Be sure when cycling the throttle to not linger when depressing at full throttle. You should reach full open then release. You should only be holding at the third and final depressing of the pedal. Holding it at the wide open on the other two cycles will not trigger the pcm.
Reactions: CID and TripleB
steve_whiteside
55
108
San Diego
  2. Other Brand
wow, thanks guys. Just did the procedure and it seems to be working. Let me put a few days of shifting on it. As I look back I should have addressed this at the get go...
5,015
22,383
None of us were born knowing this stuff.
"Until our dying breath, life is a lesson imperfectly learned." Unk
