Noticeable improvement on the 3 seater. I'm leaving it off for the summer for sure. Also makes checking oil a whole lot easier too.
So you were doubting my wisdom and knowledge
Ahhhhhhhhh, yes and no... Hadn't heard of it before but I guess that's because most on here have the 5 seater and that's really not an option for them... Good catch @pgiannetto65So you were doubting my wisdom and knowledge
Great idea! I have a 3 seater.. I tried this it help a little.I posted a couple of months ago about removing engine cover to fix heat problem. I'm here to tell you guys it's such an easy fix. I've been running it a couple months now and I'm almost ready to say problem solved. I want to run it some more on hot days and I'll let you guys know my results. Just for the record I have a 1000-3 with roof, split windshield, and back panel. I think I'll always have a little bit of a heat issue with my setup but nothing like I use to.
I got the idea to remove the engine cover from Polaris and Yamaha. I noticed there engines were not covered and allowed engine heat to escape. Here is picture of cover removed
That sounds awesome!Noticeable improvement on the 3 seater. I'm leaving it off for the summer for sure. Also makes checking oil a whole lot easier too.
Awesome.. did you make more?Hope to solve the hot air thru the shifters. The plate is held to the dash using studs screwed in the existing screws then bolted. The
rubber is glued to the aluminum on one side and thin foam weather stripping on the other to complete the seal. No drilling or cutting involved. I will install in the AM and post effectiveness and a photo
View attachment 45361 View attachment 45362
Try it out let us know and I believe you could sell lots. I would like one as well.
Just took my cover off. I'll give it a try soon. I already like the access to the engine waaaaaay better.Noticeable improvement on the 3 seater. I'm leaving it off for the summer for sure. Also makes checking oil a whole lot easier too.
Only if you have a 3 seaterJust took my cover off. I'll give it a try soon. I already like the access to the engine waaaaaay better.
This could be the answer.
Yup, that's what it be.Only if you have a 3 seater
