P1000m3 Heat problem a simple fix
E
elkguide
3,377
7,964
Vermont
As has been said, does cut the heat some and as a bonus it cuts a little more sound.
Reactions: JTW
I moved my bilge fan so it was blowing directly on the manifold Sat. The front passenger seat crack is 20-25 degrees cooler. The back passenger floorboard didn't seem to be any different with an IR temp gun though. I'll probably wait and add the PCV with auto-tune once it's out of warranty that seemed to help @joeymt33
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
I've had more of a chance to ride since I removed my shield. It makes a significant difference. I don't run fans under my seat but do have the barrier sold by another member. I don't see me adding the fans either... Today, @Delton and I will be riding and creating steam... I'll report back again.
truc577
truc577
130
360
NEMO
So far the 7" fan has made a notable difference in the front and was easy to put in. The back is better on the passenger side but drivers side is the same
Reactions: CumminsPusher
Dasmoeturhead
Test ride today without engine cover went ok. The heat is still present, but I believe its better. Another longer ride is in order, but with the seat shield, and no engine cover, I think this is going to work.
Reactions: Tigermark
0860silverado
959
1,848
louisiana
I'm willing to give it a try but my question is... Why on God's green earth would Honda have put that thing there to begin with??? It's a heat trap and makes it a PITA to check the oil!
0860silverado
959
1,848
louisiana
Maybe they knew they needed it for the 5 seater (rear passenger feet) so it comes on 3 seater also? Are the 3 and 5 seaters running the identical frame built on the same assembly line?
Dean1K3
Dean1K3
38
68
Osteen Fl.
I agree as well! Checking the oil with that shield is impossible, lol. I made a seat heat sheild and removed the plastic shield in back. "So far so good" - but it's rained for 3 days straight & no sigh of ending soon. I'll post when the sun pops out.
208,731
Fans, is the only why to fix the heat issue, been there, tried the heat shields, they protect steam flash and that's about all.
Dean1K3
Dean1K3
38
68
Osteen Fl.
I just installed my second battery yellow top under the seat, fan is next.
drfubar
drfubar
TheDonFather
5,889
19,242
I wanted to update removing the engine shroud on the 3 seater after @Delton's and my ride on Tuesday at Bull Run. I splashed through several water and mud holes and didn't once feel heat or steam come up between the seat where it normally did. I did feel it redirected between the back of the seat and the front of the box. It wasn't bothersome at all and not hot on your ass or back where it used to be. When I got home to clean the mud off I popped the bed up and it was soooooo much easier to get at the engine with the shroud off. This definitely helps on the 3 seater Honda.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I reported somewhere on here that my 7" fan was about the same as my two 3" blowers. Then last night I made a startling discovery. Some idiot forgot the heat shield under the seat after installing the fan lol. So I think I may have proved (to myself anyways) that the fan is better in my case. With that heat shield in place I'm sure the seat will be cooler.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I've used my rear seats maybe 3 or 4 times in my 18mos or so of ownership. I'm thinking I may remove my shroud. To use the rears, I have to install seats and 4 point harnesses anyways. What's an extra part to I stall?
322,776
That makes more sense. We don't have undershield and it's not bad
Reactions: Delton
drfubar
drfubar
TheDonFather
5,889
19,242
Finally got my new tie-downs installed. They will be a lot quicker and hold nicely.
https://amazon.com/gp/product/B015CJICIK/?tag=sxsweb24-20
20170608 1243281
Also installed my new trailer leds after I knocked the others I had on there off on Tuesday...:mad:
I take great pride over the years in how well I've backed and positioned any trailer I've used up until now...Two in one day has got to be a record.o_O
https://amazon.com/gp/product/B01MYN0EFB/?tag=sxsweb24-20
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Amazon.com: Erickson 09160 Wheel Chock Tie-Down Kit: Automotive
Amazon.com: 12V LED Trailer Tail Lights, AUTOSAVER88 WATERPROOF & ANTI-SHOCK Turn Signal Brake Tail Light 20-LEDs Red 12V: Automotive
Dude that looks so much better than your prior setup. I bet they hold solid too. Big improvement.
