P500 Heat Shield Insulation Blanket To Reduce Cab Noise
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
On a previous Polaris Ranger 800, I added a heat shield/insulation blanket under the seat and was able to reduce heat in the cab significantly. So, has anyone added a heat shield/insulation blanket under the seat to reduce heat and/or cab noise on the Honda Pioneer 500? If so, what product(s) did you use? I am not experiencing any heat issues given the temperatures outside, but I would like to get the noise down and suspect I can get that done, but thought of asking first before spending money$$$
178,998
Lots of us have done it. Everyone has their preference, foil backed carpet probably being most popular. I used it but didn't like how it would get soaked and then have to be dried out or it would mildew. I switched to roofing rubber, heavier material so blocks both heat and sound better. I can power wash it and never have to take it out.
906UP
906UP
14,275
135,422
da Yoop
I've tried a few things with limited success, we finally decided wearing earmuffs/earplugs works the best. These are noisy little suckers!...lol
rocmar
rocmar
4,741
5,776
4 CORNERS
Lots of choices. ...
don't use any material. ..
that would create a nest...
for mice...or hold water....
mine is like...tin foil..
covered...bubble wrap.
I run it..from bottom of
seat...all the way up to..
top of roof...
alloutdoors
alloutdoors
1,022
2,184
US
top of roof...
Thanks for the note and will being working on it soon.
Reactions: rocmar
alloutdoors
alloutdoors
1,022
2,184
US
Is the noise coming from the exhaust or the intake? (I know the dif is stupidly loud)
I see many gaps, opening, etc., between the rider and the actual engine allowing noise direct access to the rider. What I am wanting to do is create a barrier like in a car (essentially a firewall with dead sounding materials) to make the cab experience more enjoyable. I am not concerned with the muffler at this point, but may want to touch that at some point as well.
rocmar
rocmar
4,741
5,776
4 CORNERS
Sound barrier..under Tractor Fabric
..from bottom of seat..to back
..of roof
20170611 124540
Reactions: trigger
P
Ppndabum
Maine
Any pics? I have some old conveyor belt kicking around at work that I could "borrow".
RumpRocket
189
295
USA
I also went with the thick rubber roofing material, I installed mine in the cold and found it laid down really nice, probably even better when it's warm. I started with center seat belts and worked outwards. I only made cuts large enough so the seat and back could be re-installed. The extra material in the back I left long and just roll it up tucking in neatly in the air filter area, thinking it would block more noise.
Reactions: trigger
P
Ppndabum
Maine
I may not go that extreme. I was just thinking about running it from that rear bar down to the back of the seatbelts. No way I would get the material I want to use to spread out like that. To stiff. Awesome idea though.
Reactions: trigger
178,998
I probably did go further than I needed to but had the material and figured it wouldn't hurt. I have a second battery right under my ass too and have read about electrical fires. The more you put in will help keep it from moving around.
178,998
Excellent idea! Where did you locate that?
Better idea, you need a Trigger Shield. Here's a link.
Reactions: Mudder
Todd627
Todd627
56,720
619,275
MI
^^^this x1000+^^^
AF51CAD7 C722 48CF 84E4 933E2112C029
Reactions: trigger and Mudder
Mudder
Mudder
NTC Ambassador of Walls
11,660
88,041
Like others mentioned, current triggershield is a great choice. Some other barriers with padded material hold water and end up in the trash after finally getting a Five Star trigger shield for the P500.
