When the sun goes down and temperature drops it great to get some hot a$$ for the ride home.
I ordered the Crimestopper seat heater I mentioned above. On high - they are nice and toasty - after about 10 minutes you have to switch to low heat. Thats just what I would expect from heated seats
They come with a warning not to modify the wiring harness in any way but I wanted to use the rockers I bought. The wiring in the harness is a bit wierd. On high, the heater elements get 12V, on low 6V. What got me confused is the switches on the wiring harness have a voltage reduction circuit to provide 6 or 12V. I was trying to figure out what the harness did using a voltmeter but eventually I got frustrated and just hacked off the switch and started applying voltage to the various wires to get it working. It turns out that the voltage reduction in the switch is not needed because the switch just feeds the relay coil.Kinda obvious but it was confusing.
There is something else in the harness that also reduces voltage - I bet its the relay but I didn't bother to find out once I figured out that the my switches would work.
I figure they tried to get away with just the switch in their design but they burnt up so then they added the relay.
If you remove the supplied switches like I did, you can ignore the black and red wires in the harness to the switch. Power and Ground should be connected to the black and red wires that were exposed when you opened the package. The switch does not need them. The white and yellow wires going to the switch are the low and high triggers (+12v) to the relay.
Install is straight forward.
Remove and clean the seats.
Apply heat reflective tape.
There is tape on the elements to keep them from sliding around
That's my boss telling me to get back to work.
View attachment 10761 View attachment 10762 View attachment 10763
I used the Honda seat covers. Wires hang out the back.
View attachment 10765View attachment 10766
I built a wire harness to go from my switch panel on the dash that splits to feed the drivers seat and passenger seat. It also splits for a wire to get the reverse ground trigger. This harness follows beside the Honda main wire harness. Three position switch - up = high, middle = off, down = low. I left most of the supplied wire harness intact and attached them under the seats. The wires from the relay to the lower seat were lengthened so the seat can be put on the floor without disconnecting them. There is a quick disconnect on all 4 heater elements so the seats can be easily removed.
View attachment 10764 View attachment 10767View attachment 10770
I wasn't sure I would like the camo seats on the grey 1000 but I think they look great. You can see in the second picture where I fed the wire harness from the upper seat under the lower seat.
View attachment 10768 View attachment 10769
Well that turned out to be a bigger write up than I expected ....
