Hello from KenandCen
K
KenandCen
9
11
Hello, I'm KenandCen
My wife and I are new P1k owners are really like the machine... but its been in the shop since Oct 4.
I took my 2016 Pioneer 1000 in for the clutch update. The unit had only 250 miles and was experiancing no issues (ran perfect, but I wanted to get ahead of the curve on the clutch). The update was installed Oct 4, 2017, I picked it up brought it home and after approximately 30 mins the Oil Pressure light came on. I stopped the unit checked all fluids and all were okay. I took the unit back to the dealer and they have not been able to find any problem, except the light comes on once the unit really warms up (about 30 mins) There are no codes, no performance issues... nothing wrong except the light.
Today the Honda District Manager suggests there may now be a pinched wire in a harness that is causing the problems so they are looking at that.
Does anyone on here have any thoughts on this issue?
Here is a little info about me to begin with!
Honda SxS ownership : Yes
I have owned, or currently own the following: UTV, ATV
My off-road experience level is: Trail Rider
My favorite place to ride is: Soggy Bottoms Msiiouri
Reactions: Miss_Oak
7,140
27,147
Welcome from Texas
13,358
65,050
Welcome from Cleveland!
Has the dealer tried re-installing the update again? Replacing all seals with new etc. If it were a wire, I would think it would take less than 30 minutes to show up.
Push them to start fresh with a new install of all new seals. Sound like a nicked seal to me, where once the aluminum warms up and tolerances get loose, a bad seal trips the oil light.
Easy way to diagnos seal vs wire, is test for actual/physical oil pressure with a gauge when light comes on. If pressure drop, look at seals, if pressure is fine. look at wiring.
Reactions: Hawkeye and Eltobgi
K
KenandCen
9
11
Neohio, thanks for the reply..
The say the Tech did check the oil pressure and it TOK .... and there are no leaks or any other sign of a physical problem. I'm leaning towards the new seals ideal at this point
Reactions: Eltobgi
swsebek
swsebek
2,854
5,828
pa
Welcome from Pa
A
Andy_Corbin
Buffalo MN
Sounds like you are having similar luck as me. I purchased a 2017 p1k limited and have had it in the shop 4 times now... it has been having a shifting issue 2 times, stuck in 2wd, and recently a front dif oil leak today... 463 miles...... I've been having problems since 200 miles. Today I told the dealer to keep the pos....
Bigtee
Bigtee
556
1,213
Grayson, KY
Welcome from Kentucky
R-Lamm
R-Lamm
315
242
South Carolina
Welcome from SC! Good luck on repairs...hopefully you will be back and playing soon!
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Welcome from SE Missouri
265,448
Welcome to the forum there is a lot of good information and people on here.
13,358
65,050
@superman
This is the thread we are referencing in your welcome thread.
Tuco69
Tuco69
1,474
7,563
Middle Georgia
Hope it all works out. I am waiting on a local dealer to get the parts in to do mu updates. Welcome from Georgia!
