HELP!!!!
xltman
xltman
188
369
US
I just got done installing my new Superwinch and now have a major problem, the unit won't start!!! I also have no display, the unit DOES turn over. I checked all fuses and battery is charging, currently at 75% I spliced into the accessory power at the cigeratte lighter. I pulled power off of the stock battery. I'm lost and pissed. Please help.
7,171
27,465
Ok lets backtrack. When you turn on key you get nothing correct? Is so lets remove the connection where you spliced into auxillary harness.
7,171
27,465
Also one other thing, i noticed that when i removed the battery connections that the nut falls down and is a bi+# to get bolt rethreaded.
xltman
xltman
188
369
US
I just checked, have 12.56vdc in the connector. And yes the bolts are short but have them on.
Reactions: Tramguage1
xltman
xltman
188
369
US
Just verified that the key ignition is turning the outlet on and off
7,171
27,465
Is yiurs a 15 or 16?
7,171
27,465
Let me look at the wiring schematic
xltman
xltman
188
369
US
Sorry, it's a 16 700-4
xltman
xltman
188
369
US
Headlights come on, winch works as it should
7,171
27,465
ok you said the display is blank,No lights either? also do you hear the fuel pump come on for a few seconds when you turn the key to on?
xltman
xltman
188
369
US
Nope
7,171
27,465
the drawing I'm looking at is for a 14 but I would say its close. it shows fuse F is a 10Amp and is the ignition supply. can someone turn cycle the key switch for you and see if any relays under the hood are energizing? (clicking)
xltman
xltman
188
369
US
Nothing, so the ignition is turning some things on but not others
7,171
27,465
looks to me like fuse A and F are the supplies for the Ignition and start circuits. didn't unplug any connectors under hood or dash?
7,171
27,465
didn't pull any fuses either?
xltman
xltman
188
369
US
Nope, just the accessory connection. And when I was doing all of the wiring I had the battery unhooked. I just checked continuity on all of the fuses.
7,171
27,465
how about temporarily removing all the wires you hooked up and then try it? not saying you made a mistake just lets see if we can get it running again.
xltman
xltman
188
369
US
Trust me, any idea is good at this point, unfortunately I already did that. Somewhere the ignition signal isn't getting through, just can't figure out where.
xltman
xltman
188
369
US
From looking at the schematic I'm thinking it's something in "Junction 4". Does anyone know or can they post a pic of which one is junction 4?
7,171
27,465
Sorry im at a wedding, ill geg back to ya as so as i can.
