P500 Hesitation
JonnF3
14
Ohio
Just purchased a new 2019 P500. Each time I start it, I let it warm up a bit. However, once I get it in gear and take off it hesitated like it’s starved for fuel then lurches forward and hesitates again. Any ideas?
Reactions: DG Rider
Mudder
Mudder
NTC Ambassador of Walls
11,404
85,220
When I was doing a clutch adjustment, I went too far and caused mine to briefly die out like that, like the engine retard during shifts was kicking in. Re-adjusted to sweet spot and been fine since. If adjustment doesn’t fix it, warranty service?
P500 - Pioneer 500 Clutch Adjustment (Video)
Reactions: JonnF3
42,240
Is this also happening in manual mode?
If it's only in auto, then it's prob just not pulling off the shift and it's the ignition cut out your feeling. Those 1st couple of shifts are always notchy, regardless, but as @Mudder said, clutch adjustments on these can make a word of difference.
JonnF3
14
Ohio
To be honest, I haven't tried it in manual. I’m gonna try the clutch adjustment and recheck. Thanks for the input.
Reactions: Mudder
NTCPrezJB
NTCPrezJB
President of #NTC
102,808
918,756
Canton, OH
Welcome to the forum from Canton, OH. Post up a pic of the new ride. Hopefully it is red, because that is the fastest color Honda makes.
[HASHTAG]#NTC[/HASHTAG]
Reactions: Mudwing
futzin
futzin
3,508
25,702
Kentucky
From what I've read, new ones can be prone to a shifting glitch. Mine has done it two or three times. Not sure if what you are describing is the same. Basically, it won't upshift and the digital dash shows a dash instead of a gear number, as I recall.
There's a post or two about it, I think.
