Ok.. so with all the questions on the HID light installs thanks @CumminsPusher making this awesome suggestion.. I took some pics for reference and how to..
Tools needed...
black tape
And a HID slim ballast kit.. this is exactly what I ordered. 880 and 5000k
https://www.amazon.com/gp/aw/d/B00NFAA5N4/?tag=sxsweb24-20
That's it!
It's as simple as taking the cover off the back of the light housing. Rotating and pulling out the bulb, disconnecting the plug to it.. and then inserting the HID bulb into the socket. Plug pigtails and ballast into the bulb and insert positive and negative ends into the OME plug. (Black-green & red- brown) Use a little electrical tape to secure the ends, then neatly and carefully stuff ballast and wires into the light housing. Situate as desired and then recover with cap.
*You may need to adjust your head lights down.. simply insert a Phillips head into the hole below the light housing on the front side and adjust as needed
*Also, I took the foam that protected the HID lights for shipping and put it on the stock light bulbs. I put them in my toolbox, but in the light housing under the wires would be a great place for it as a backup!
After riding this weekend with my buddies and their stock lights.. These are impressive and well worth the $40-$45... I think this could be the best cheap improvement we can make on the little P500.. There is also a 35watt version if you want less light for some reason?
Tools needed...
black tape
That's it!
