P500 HID lights install/how to
Ok.. so with all the questions on the HID light installs thanks @CumminsPusher making this awesome suggestion.. I took some pics for reference and how to..
Tools needed...
black tape
And a HID slim ballast kit.. this is exactly what I ordered. 880 and 5000k
https://www.amazon.com/gp/aw/d/B00NFAA5N4/?tag=sxsweb24-20
That's it!
It's as simple as taking the cover off the back of the light housing. Rotating and pulling out the bulb, disconnecting the plug to it.. and then inserting the HID bulb into the socket. Plug pigtails and ballast into the bulb and insert positive and negative ends into the OME plug. (Black-green & red- brown) Use a little electrical tape to secure the ends, then neatly and carefully stuff ballast and wires into the light housing. Situate as desired and then recover with cap.
*You may need to adjust your head lights down.. simply insert a Phillips head into the hole below the light housing on the front side and adjust as needed
*Also, I took the foam that protected the HID lights for shipping and put it on the stock light bulbs. I put them in my toolbox, but in the light housing under the wires would be a great place for it as a backup!
IMG 0534 IMG 0535 IMG 0536 IMG 0533 IMG 0537 IMG 0538 IMG 0540 IMG 0541 IMG 0542 IMG 0552 IMG 0583
After riding this weekend with my buddies and their stock lights.. These are impressive and well worth the $40-$45... I think this could be the best cheap improvement we can make on the little P500.. There is also a 35watt version if you want less light for some reason?
FuzzyGrub
FuzzyGrub
373
532
Rural NY
www.joefishin.com
I think mine are the same as yours, and I also found the install easy. They did make some improvement in visibility, but a large difference in being noticed by others. ie I ride some on dirt roads (Slow Moving Vehicle) where it is important that car/truck drivers see me in the daylight.
I have added LEDs for night vision, but that is too much for oncoming vehicles. ;)
Reactions: JTW
ehart814
ehart814
1,654
3,643
NWPA
Tools needed...
black tape
That's it!
View attachment 24042 View attachment 24043 View attachment 24044 View attachment 24045 View attachment 24046 View attachment 24047 View attachment 24048 View attachment 24049 View attachment 24050 View attachment 24051 View attachment 24052
Good pics. Makes it easy to see when the machine is clean and new. The kits should come with a connector for the plug to the vehicle harness (mine did) so normally you wouldn't have to tape.
Reactions: JTW
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
Tools needed...
black tape
That's it!
Good job, thank you, for the visual reference. I have these in my garage and will install sometime this week
Longbrake500
Longbrake500
96
168
Anna Ohio
Looks good... Might just have to order a set of those today...lol
Reactions: JTW
There is a connector that almost works but it didn't fit the stock plug without bending the contacts and I didn't like that.
rocmar
rocmar
4,741
5,773
4 CORNERS
The tape is to keep his
Burnt nose...firmly in
place...
haha
good thread....great pics
that new machine needs
some....."DIRT"
Reactions: JTW
7,143
27,176
I just plugged the oem plug into the new plug from the ballast
Sent from my SAMSUNG-SM-N930A using Tapatalk
I wonder if this is a difference in the 17 and 15/16 wiring harness?? I'm going to go double check to see if I can get mine to plug direct. I'm pretty sure mine was significantly wider and would have caused the male connections to bend in order to fit.
Reactions: CumminsPusher
7,143
27,176
I will also take some pictures of the new ones when they arrive.
Reactions: JTW
Shadesmn
Shadesmn
505
959
Ramsey, MN
7,143
27,176
Ok my replacements arrived today. About 10min install this time.
20161015 134517
20161015 134524
20161015 134601
20161015 134612
20161015 134936
20161015 134704
20161015 134747
20161015 134810
20161015 134849
20161015 134936
20161015 135021
20161015 135610
7,143
27,176
This is a 700-4
Reactions: drfubar
Longbrake500
Longbrake500
96
168
Anna Ohio
I just got the same kit JTW posted up.. $40 and then I ordered some $8 harness adapters so that I could just plug them directly into the honda harness one I solder on the adapters. I got the HID kit yesterday just waiting on the harness adapters and will hopefully get it done this weekend and take some pics.
Reactions: Tramguage1
Martin
Martin
55
105
Mont-Laurier, Qc, Canada
Tools needed...
black tape
That's it!
What is the light patern like? I tried different lights and could not get a good light projection.... I either had a major black spot dead center about 20 feet in front of the P5 or the lights would not project more than about 30 feet.... Do you have picture of the light patern at night?
Tx,
Reactions: joeymt33
