Searched the forum but did not see any comments on an issue I’ve come across regarding the installation of the front long shock brackets on my 2017 1000-5.
Installation instructions say slide the long shock brackets behind and in front of the front OEM shock mounts. The rear front bracket slides in no problem, but I noticed a plastic shield attached to the front side of the OEM shock cross bracing, just behind the radiator overflow bottle, that is in the way of installing the front lift bracket. The plastic shield looks to be a heat shield for the radiator and is attached to the OEM shock cross bracing via 2 plastic push clips.
Has anyone else encountered this and what is the solution, or am I missing something in the instructions?
Thanks for your help.
