Cant really afford the others but @160 or 190 I could do folks where down on the highlifter for the 700 is the one for the 1000 any better and is the strongmade just 2in
Well I was hoping to do it with wide offset rims but that would be nice to have the arms. Wish I had gotten 28 in blackwaters on the stock from dealer then had the mud tires on aftermarket laterStrongmade is exactly 2" from Jackal's calculations from before and after. However, I think you should save your money and spend it on forward offset A-Arms if you want to run a decent sized tire and not worry about rubbing at all. I figured I could get away with the 2" and slight rubbing on 30's, but that's not the case, even under light trail conditions.
Wish somebody with bracket lift would buy some 29.5 terminators and try on stock wheels lol.Ya these bracket lifts wont let you run anything bigger than 29-30(depending on 30). All they will do is give you more ground clearance. You will need a 2in forward a-arm to clear anything bigger.
I would think they would fit . But it will be really close . Dealer around me is running 30in monster mayhems which run alittle small (around 29in) Terminators are true height so it would be closeWish somebody with bracket lift would buy some 29.5 terminators and try on stock wheels lol.
Honda 1000 Pioneer Signature Series Lift KitAnybody know the price on hilifter kit? Am I correct in saying it is 3 inches and the strongmade is 2 inches and they are both a bracket style lift?
I believe highlifter is going to have bracket and suspension lift out. The bracket should be out already if not soon . The suspension will be shortly behind that . Is this correct TOLOUD
Pretty sure Brad
They are going to do forward arched Front arms ( not sure on the rear )
Also the bracket lift.
I have noticed that the HL bracket lift provides a little more GC than our CATVOS lift.
You getting some seat time in your Honda? Any issues so far with turning your 30s.You get her stuck yet.I don't have a confirmed price of the HL set up but i have heard it's gonna be close to 1k for arms and bracket lift.
My P5 went from a little over 12" of GC to almost 17" from the CATVOS lift and 30" intimidators
I'm ok with being alittle lower. lol Catvos makes pretty good stuff , so I'm glad I went with them. I think we are going to have bigger issues than ground clearance down the rode with the clutch problems I've seen pooping up. Hopefully they come out with something soon for us guys that like to run bigger tires .Pretty sure Brad
