P700 Hitch Support?
JRH
31
87
Upstate NY
Hey what's everyone think? I have read others have had issues with the hitch "bending" up either by using an implement that requires a downward force or by hitting something. I printed a pattern of what I am thinking of fabing. Also may add a second receiver. Would probably weld angle directly over stock receiver. Probably use 1/8" or 1/4 plate.
IMG 3309 IMG 3302
JRH
31
87
Upstate NY
I have not thought that far ahead. Not sure if there would be enough to market or if price would be worth it. How many have interest?
Reactions: Glock21user
Buckshot07
Buckshot07
19,814
203,734
Would the aluminum plate really strengthen the 2” receiver hitch when it isn’t fastened to it?
I would at least weld a 2” long piece of steel angle to the top of the receiver tube and then bolt it to the aluminum plate.
Glock21user
Glock21user
1,815
9,039
Livingston county, Mi.
If the price is right the desire not just interest is there.
mpilihp
109
204
Maine
Im curious have people had issues with their hitch receiver bending/moving??
Phil
WagginTail
WagginTail
1,474
5,459
SC
Phil
Yea. There's some older threads on here if you use the search you will find them. I did this on my 700. I never used the hitch hard but mine had started to crack. The problem is when there in an upward force applied to the hitch. For example if you have a ball mount in and cross a deep enough ditch then the ball could hit the ground and push the hitch up. I think it would mostly be solved if honda welded underneath like I did.
20210130 132611
20210130 111005
mpilihp
109
204
Maine
Interesting, thanks I have had that happen to me already, IE hitch drag from a deep hole.
Phil
Reactions: WagginTail
