Parts fish for the Honda Pioneer 500 have been made public. They can be viewed -> HERE. This confirms the 2017 Pioneer 500 will come with a higher gear ratio than prior models. Of course, your first question may be... How can I retrofit my 2015 or 2016?
Well... That is a tough question to answer. Here are some of our thoughts.
Final Shaft Gearing.
We have confirmed different gearing. Frist look is at the final shaft gear inside the rear crank case cover. Here there is an increase from a 16/30 tooth combo to a 22/40 tooth combo on the 2017 models. Changing these 2 gears will give your 2016 P500 a higher top speed and can be done for under $70 and a few hours of time.
2016
GEAR (16T) 23621-HR0-F00
GEAR (30T) 23631-HR0-F00
2017
GEAR (22T) 23621-HP5-600 $23.22
GEAR (40T) 23631-HP5-600 $44.98
Transmission.
Here we find lots of updates inside the main transmission. Most are hard to identify as teeth count are not listed but part #'s suggest improvements. This will be difficult to change out for the home mechanic and may not provide any results.
Computer, wire harness, display.
The wire harness and computer has updated part #'s. This was expected as it now needs to handle automatic mode along with the possibility of additional sensors.
Differentials.
Both differentials remain the same and pass along the same part # between he 2016 and 17 years.
Other unknown parts.
This post is not meant to be a guide for an automatic retrofit changeover. There are many unknown parts that will be required to properly complete this tasks. One will most likely find it not worth the money to complete.
Feel free to research some differences on your own. Please, we ask you share you findings.
Parts fish link - New & Used PowerSports For Sale in Gastonia, North Carolina. Honda, Kawasaki, Suzuki, Beta, and more available. Service & Parts too!
Thanks.
2016
2017
Transmission.
Differentials.
Thanks.
