P1000 Honda Pioneer Stuck in 1st gear - Code 8 = TP Sensor
67,653
Excellent.
FYI - I'm going to edit the title to be more SEO relevant for code 8
ghost
ghost
993
1,874
BC
Hey guys - the MIL does not indicate sub code.
8 long and one short is 81 ... not 8-1
81 = Sub transmission position switch malfunction
You need the honda tool to get the sub code.
67,653
Seems like it I read something about that. I'll look it over tomorrow and correct.
Need to build a entire post on code reading sometime I guess.
But for now.. Off to bed.
Thanks.
ghost
ghost
993
1,874
BC
Symptom: Gearshift function does not work
Check page 4-6 under MIL Blink Pattern for how to read the codes.
Later... :D
67,653
Yep, your right.
But seeing his problem is fixed...
I'm just going to edit this post to be info for code 8 since that aligned with his symptoms.
