P1000 Honda Roof + SuperATV Flip Up Windshield Clamp Question
BigOL3
BigOL3
2,994
8,919
will need some encouragement regarding said hills! i haven't cared for them since a child and there's one climb and descent quite steep i always steer clear!
definitely want to see the p1000-5's at their best
i believe it all began one fateful morning turkey hunting with my father and falling on a hill and my gun went off...
downhill, pun intended, from there!
That P1K is a virtual mountain goat!
Reactions: TripleB
bs4u00
30
46
WI
One more tip, leave all the roof clamps loose until you have the windshield fully installed.
Reactions: Hondasxs
tigerj
tigerj
Louisiana
It will all fit and yes those front clamps have some adjustment. Your windshield clamps will sit very close to the roof clamps as you can see in the video below.
russ, do you have a link to part 1 of your video? thanks!
Reactions: Russ989
tigerj
tigerj
Louisiana
sorry everyone, i have some neuro issues at hand but can't seem to figure out how to remove clamp? there should be somewhere to loosen & guidance on what tool would be appreciated.
i have loosened roof bracket screws, the other 2 screws on bracket don't seem to accept my 4mm hex-do they affect clamp opening or just attach clamp to bracket
the backwards install has me backwards sideways and totally confused!
clamp roll bar adjustment loosening tips helpful & appreciated.
i can open clamp but not remove it (or move it) from bar
will switch their position and outside front brackets as well when loose.
pics of as is
AB2A36E2 C8E8 40D3 A975 37B42659A1A8 DF1847B1 0115 4684 A4D1 A2D544DD2AA3 72D5F866 0149 4773 8379 6E35D83B0512
Reactions: Russ989
Russ989
Russ989
22,588
146,743
pics of as is
View attachment 170486 View attachment 170487 View attachment 170488
F67A12F1 939F 4582 993E 4B930760BD24
Russ989
Russ989
22,588
146,743
thanks russ!
THANK YOU! i'm a visual learner this is amazing
how do i loosen the clamp? it should be so simple
You’ll have to use an Allen wrench on the back side of the clamp to take it off the bracket and then use it again on top of the roof. Then spin the clamp down to you so you can unbuckle it and take it off. Your welcome buddy.
207,989
thanks russ!
I just have to laugh, I wad up the instructions to build a fire with, before I start the install and never read them! HA! Got a Grandson coming March, a couple of years from then I will be assembling some yard play stuff, should be interesting!
Russ989
Russ989
22,588
146,743
You’re interesting by yourself Smitty, you don’t need help! :D
Reactions: Mudwing and TripleB
