I am having issues with my power steering on my talon x4. It gets stiff from time to time. I have checked the battery by load test, connections, grounds and loose wires. Has anyone else had this issue?
@my99svtI am having issues with my power steering on my talon x4. It gets stiff from time to time. I have checked the battery by load test, connections, grounds and loose wires. Has anyone else had this issue?
Sounds like product improvement campaign is comingI am having issues with my power steering on my talon x4. It gets stiff from time to time. I have checked the battery by load test, connections, grounds and loose wires. Has anyone else had this issue?
Yup, acts like the front diff is locked, notice it most on dry pavement when going slowI am having issues with my power steering on my talon x4. It gets stiff from time to time. I have checked the battery by load test, connections, grounds and loose wires. Has anyone else had this issue?
Only if i run the tires at less than 10 psi. If your front tires are low and you are on a hard surface like pavement or hard pack then the your power steering unit will not be able to keep up.I am having issues with my power steering on my talon x4. It gets stiff from time to time. I have checked the battery by load test, connections, grounds and loose wires. Has anyone else had this issue?
This is where I'm at.... do I notice it? occasionally.... I really don't see it as a flaw or defect, just a quirkI notice it occasionally since I put 30X10X15 tires on (stock tires never did it and neither to my 28" sand tires). Mostly dry pavement when stopped or going real slow but it is not consistent and doesn't happen very often. I have learned to roll slightly when it happens and after a couple thousand miles, I really don't pay much attention to it anymore.
That’s kind of where I’m at with it. It’s weird though, went on a trip to Colorado rode almost 200 miles with no problems. Then got back home and got it it one day to go for a ride and started noticing it. If sitting still it doesn’t assist at all.I notice it occasionally since I put 30X10X15 tires on (stock tires never did it and neither to my 28" sand tires). Mostly dry pavement when stopped or going real slow but it is not consistent and doesn't happen very often. I have learned to roll slightly when it happens and after a couple thousand miles, I really don't pay much attention to it anymore.
How old are you? Most Leo's are dickheads. I turn 46 tomorrow. Lol
Mine does it when I'm making a U-turn (doing K-turns on a narrow trail). I back uphill, usually pretty steep and the nose down attitude with lots of weight on the front, it'll occasionally hang up until I let it roll a foot and everything returns to normal. Occurrence may be once or twice a day. Stock wheels and tires.This is where I'm at.... do I notice it? occasionally.... I really don't see it as a flaw or defect, just a quirk.
They also have a YouTube video and the installation looks fairly straight forward and looks like it can be done in an hour or so...ePowersteering.com has come up with an upgrade. Fully adjustable and is so powerful it requires you to use the big winch power cables for the power source. It is a direct fit kit with on modifications required.
If I get tired of the occasional "blip" or if it goes out completely, I will probably upgrading it. It is slightly more expensive than a stock EPS unit...
Complete Honda Talon Electric Power Steering Kit - ePowerSteering.com
KIT-07 Complete electric power steering unit for 2019-20 Honda Talon. Includes rebuilt EPS unit, steering ECU, EPS controller and harness, 60 amp fuse, output and input u-joint, powder coated brackets, misc bolts and washers, and wiring instructions.epowersteering.com
The dummies put the power and ground studs where the winch contactor lives. 🤔They also have a YouTube video and the installation looks fairly straight forward and looks like it can be done in an hour or so...
I have seen this setup. I didn’t want to pull the trigger on it if someone had answers to what may be going on with mine.The dummies put the power and ground studs where the winch contactor lives. 🤔
If it's new enough, it's Honda's problem to fix. If it's only once in a while like mine, I can live with it. If mine poops the bed, I'll keep this in mind but I'll have to relocate the power studs. I'll have an auxiliary battery by then running the winch and steering so everything will be a bit different. It still irritates me that they aren't aware that's where Honda expects the contactor to be, mine was installed by the dealer before I took it home.I have seen this setup. I didn’t want to pull the trigger on it if someone had answers to what may be going on with mine.
Same issues.mine has done that since day one, i can be turning and all of a sudden it gets hard (way short of the lock)
the first time i noticed it was when i was picking it up from the dealer and turned it to get it on the trailer, i asked and they said it was normal and it would work its way out.. well it hasnt..
feels the same on the stock tires as it does on the 32's i have on it now..
maybe someone will come up with a fix..
21 x4lv
