P1000 How Many WATTS you running
ghost
ghost
993
1,873
BC
If I had everything running the rated amperage is 75 amps.
My heaviest load would be on a cold rainy night with most lights on, windshield wipers, seat heaters (yes i'm serious) and the gps and radios taking a full charge it would be about 50 amps.
I have the LE and it has the LED Headlights from the factory, does your rig have the LED Headlights ? Would like to know what they draw
LED head lights are 3 amps and high beams are 1 additional.
Reactions: sharp and utvmi
Power steering on smooth concrete, vehicle not rolling, working wheel back and forth.
5 amps
Power steering at full lock...
15 amps
40" light bar labeled as a 240 watt. Actual is 195 watts or 16.2 amps
CP: I've been saying that since that jack wagon was picking Legos from his turds:)
My 4 cube lights up front are only 5.5 amps combined.
4" bilge fan is 2.8
That's all I measured for now.
utvmi
utvmi
265
574
@joeymt33 What are you using to test it ?
Reactions: sharp
I had to change my battery so I hooked a multimeter in line between the cable and battery terminal to take the readings. I took the higher amp readings with a DC clamp meter around the positive wire. Reading were taken with the motor off so the in-flowing current wouldn't mess up the readings.
utvmi
utvmi
265
574
Thanks for the info I just ordered a clamp style and will be taking reading as I go on all the lights ECT, I will also post them all up under my build and here.
All the leds are Auxbeam seems alot of people run them, can't wait to see what they truly draw
Reactions: sharp
You probably already know this but just in case, make sure the clamp meter will do DC. A lot of the cheaper ones only do AC.
I've got a lot of Amazon lights at the house. I would say maybe 12 different kinds. Most of them are Mictuning or Auxbeam, if anybody's curious, I can take measurements of the individual lights.
ghost
ghost
993
1,873
BC
I h
I had to cha. Reading were taken with the motor off so the in-flowing current wouldn't mess up the readings.
I forgot about that - I would have been confused for a while if I did what I planned - lol.
I might try to isolate the incoming and measure outgoing but i'm guessing you would have done that already if it was easy.
utvmi
utvmi
265
574
Reactions: sharp and JTW
That looks like it'll work for just about every application you want to test except for a winch. I might have to get me one of those too, it's smaller size and smaller clamp would work a lot better in tight spaces.
