P1000 How many years from Factory Stock Battery? Replacement recommendations...
2018GMC
2018GMC
174
356
AZ
My 2017 1000-5 Deluxe isn't happy in cold weather. Its always started but i've been hearing more relay clicks than usual when turning over in freezing or below 40 degree temps. Once I ride it awhile it starts fine but after setting overnight it turns over slow with lots of relay clicks. The instrument cluster will go dark while cranking.
First owner kept it on a Battery Tender. The battery shows 12.9 volts, even after sitting for a week. Key on is 12.2 - 12.3 After starting voltage is 14.2 - 14.7
Looks like after 2 - 2.5 years I need a battery?
What do you all recommend? Do you keep yours on a battery tender when not in use?
Stock replacements? Yusa, Walmart, Amazon
Better?
Best?
Reactions: BWAF
2018GMC
2018GMC
174
356
AZ
Mine is stock, no winch (may add in the future) or aftermarket accessories besides a street legal kit.
Reactions: Isaiah and BWAF
lee
lee
Village Idiot
2,386
13,516
Springfield Ohio
I know many will not agree with me but I like Yusa.
They have good longevity, and a high price.
I would rather pay once and be done.
I have noticed on my fleet of ATVs that if the battery sits at the steelership for a long time the performance is just sub par.
A new battery that gets occational use will last well, even with Ohio winters.
On my p500 I did find the dealer added a battery tender wire to maintain the battery.
So far so good.
P1000_DLux
P1000_DLux
Its Only an Opinion Relax
Belfair, WA
Will adding a second battery help with longevity if your don't use a ton of add ons?
Reactions: BWAF and Isaiah
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
2016 1000-5 with factory yusa for 1st year then added second factory battery been great and I have winch, big radio,and lots of lights, no tender but runs every day twice a day
Reactions: Haldog77
0860silverado
954
1,834
louisiana
2016 Stock battery (YUSA???). Never had a tender on it. I only run the machine 3 days per month consecutively so every month, it sits unstarted for 27-28 consecutive days. Stock battery just died last month after 3 plus years. (Better than I've been getting from my auto batteries which are used every day!!!). Can't complain about YUSA.
Reactions: TripleB and BWAF
GPR1500SC
GPR1500SC
861
2,425
North East MO
  2. Talon X LV
2016 deluxe 5 stock battery is weak cannot winch very long or it will kill the whole machine or the transmission will start acting goofy
Reactions: DDDonkey
Dirtstiffs-1000
Dirtstiffs-1000
1,657
6,033
hondasxs.com
Yuasa, great batteries.
I've got several in service, some around 7 years old and still going strong.
Keep them on a tender.
A good percentage of other batteries are made by Yuasa under a different brand.
Made in the USA.
Mopower58
Mopower58
Unburdened by what has been!
79,806
708,707
Crystal Springs,Ms.
2016 P1K factory battery still going strong, warmer climate, no battery tender.
Reactions: Remington
DDDonkey
My stock battery is good after 2.5 yrs but my second battery is getting weak, I can't winch for more that about 20 sec. I am going to replace both batteries just for piece of mind in the next few weeks. The AZ heat takes a toll on them, I do have them both hooked up to a battery tender also.
115,700
I’m still on my 16’ as well and still going strong. It’s cold up here but mine stays in a heated barn. If I’m at the cabin and it’s well below freezing it will not start the buggy. But I’m still holdin on.
Reactions: Mudwing and Isaiah
Dasmoeturhead
2016 1000-3 still working. Stock with winch. Battery tender is used sometimes, but mostly not. I'd buy another stock battery if needed
115,700
Which Yuasa battery would I need for my 18 deluxe.
I’m not sure off hand on the number? But if you take the clamp off your battery and the rubber sleeve, the part number is on there. You can also take that number and cross reference it to any other brand to fit the machine
T
T-County
26
46
Tennessee
So far so good.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
2016 1000-5 still working. Stock with winch. Battery tender is used sometimes, when I can't use it because I have to work over time like right now Walgreens is making most work there day off.
