ehart814
This is a very easy job that can be completed in a home garage.
Time required:
You need:
If you aren't super familiar with this type of job, do one side at a time so you can refer to the other side if you are unsure of something.
1. Lift vehicle and remove front wheels.
The plastic shield is held on by two bolts. Use the 10mm socket to remove them. You can turn the wheel to one side or the other to make it easier to access them.
Time required:
- Novice = 2 hour
- Home mechanic = 1 hour
- Skilled mechanic = 30 mins
- Dealership = 3 hours.
You need:
- New brake pads
- 10mm deep socket with ratchet
- 12mm wrench
- 17mm wrench
- Screw driver or pick
- Small wire brush
- Sil-glide or brake pad grease
- Brake cleaner
- Rags
