How to Quiet Down the Click During Shifts
Dirtstiffs-1000
Dirtstiffs-1000
1,734
6,257
hondasxs.com
I rarely trust what a dealer tells me. I've been led down the wrong road too many times. Anyone else believe this?
No
I do not believe it. I have - had several wet clutch Hondas that I run Mobil 1 4T Racing, full synthetic with no second thoughts. I wouldn't f around with cheap juice on this one.
20170312 125003
Reactions: TripleB
Dankathy
300
855
Only use it in the sub trans, there isn't any transfer between the engine and sub trans oils.
I've only been a Honda Tech for 12 years i would never suggest moly oil in any wet clutch application.
Does a heavy moly oil like the honda hp4m seem to help with the gear whine? Is there something that is honda approved that would? I went to synthetic in the front and rear finals and I cant tell much difference
HondaTech
Are you referring to the noise at idle?
That noise is pretty much unavoidable, since the drive gear is sprung.
Reactions: Remington
Dankathy
300
855
Thinking more of the noise at speed. Low range seems louder than high, four wheel drive seems worse yet. No change since new so no problems are expected, but if a simple change of oil type would possibly quiet things a bit it would be worth doing. I have a hard time identifying where the noise comes from but i believe it is the sub transmission. Going to synthetic in the finals made no apparent difference.
5,759
26,448
The gear whine in my Talon is painful, even for short distances, ear plugs or muffs are mandatory for me, even with my helmet. Sitting still idling isn't a problem. I'll be trying the moly in my sub tran and synthetic in the diffs after break-in. Do not put the moly in the engine/DCT.
906UP
906UP
15,061
143,164
da Yoop
Mine had a horrible gear whine from the front when 4WD was engaged, try changing your tire pressure. The front gear ratio is slightly different, try running 16psi front & 13-14psi rear, it will help. I also changed the front diff oil to Redline Shockproof. The combination of those 2 changes made the noise almost disappear.
FYI, changing to Mobil 1 Synthetic gear oil made the front whine worse 🤷‍♂️
hondablimp
hondablimp
MN
changed my sub trans to honda hp4m , no more bang when shifting to L H or R, this was only a problem cold. whine seems the same, worse at low speed. I do warm up engine before shifting, basically get it off high idle. I dont think the sub trans fluid gets warm sitting still. I have gotten a lot of good info on this site, Thanks
Reactions: Montecresto
F
fartsalot
223
337
Near the Kansas Nascar race track
Shockproof is good for the sub as well.
Reactions: IDIOT and 906UP
russknight
russknight
1,910
7,514
Perry Florida
What is the capacity of the sub T? I'm lazy.... 🤣
TalonR65
TalonR65
34
47
Tucson AZ
I have used shock proof in motorcycle trans for years. Excellent results.
Bigc2710
12
40
Louisiana
I was told by dealer to NOT use full syn because the clutches would start to stick after a few hundred miles. On my unit the shifting noise has really tamed down since the first 150miles have been put on it.
the clutches are not located in the sub trans so that really wouldn’t matter I don’t think
