Is this an OEM Hard Top or ??
Look’n good!Finally got all my parts in!! Replacing the front right tie rod ( downed tree jumped in my way...) Full skid plate from Super ATV, Elka stage 3 shocks, all the stuff to run my vent lines up higher, under hood snorkel, injector harnesses from Honda sxs, stuff to try to seal out so much dust from coming in the gaps around the doors, shifter plate cover and a bunch more odds and ends....
I installed the new tie rod and had time to install the front and rear Elka stage 3 shocks.. (no driving time yet on them but I am sure the ride will be much better then stock!!!
View attachment 248456View attachment 248457View attachment 248458
Thanx brotha!!!Look’n good!
Will update with pics when I install it... prolly have time this Saturday...Looking real nice!! Interested to see if the SATV skid plate has any overhang on the sides of the rig.
Awesome machine. What door seal did you use and are the glued? Thinking of doing same.Had a lil time this weekend to get a few things done....
Installed some seals on the doors to try and help with the dust roll in...
Mounted up the 3' whip lights ( not wired yet) They will only be used when running around in the mesa where there are no trees... that's why I ran them up higher then the roof. When I go huntin, I can remove them quickly
And got a material list of what I need to build the double bow holder....
View attachment 252134View attachment 252135View attachment 252136View attachment 252137View attachment 252138
Thanks NM! Very nice rig.Thanx!!
I first cleaned the door areas with soap and water, then wiped the areas with IPA and let dry..
I used the adhesive promoter ( for better results)
I used this seal for the front doors ( one package is enough for both front doors)
And I used this seal for the back doors ( 1 package did both rear doors.)
It came out really good!! I have not had a chance to test it out yet, but I am sure it will be 100% better then it was!!
Have not had a chance to really ride yet... but I plan on being able to in another 3weeks... I am looking forward to it!!Nice set up. Have you tried out them shocks yet?
