P1000 Huntin Rig!!
NMelkaholic
NMelkaholic
89
241
New Mexico
Finally got all my parts in!! Replacing the front right tie rod ( downed tree jumped in my way...) Full skid plate from Super ATV, Elka stage 3 shocks, all the stuff to run my vent lines up higher, under hood snorkel, injector harnesses from Honda sxs, stuff to try to seal out so much dust from coming in the gaps around the doors, shifter plate cover and a bunch more odds and ends....
I installed the new tie rod and had time to install the front and rear Elka stage 3 shocks.. (no driving time yet on them but I am sure the ride will be much better then stock!!!
12183
12184
12188
View attachment 248456View attachment 248457View attachment 248458
Look’n good!
Reactions: Biteme
Wormz72
Wormz72
10
51
Illinois
Looking real nice!! Interested to see if the SATV skid plate has any overhang on the sides of the rig.
Reactions: Biteme
Sourdough
Canada
  2. Big Red
Looks nice in the pic but they would not stay long, where I hunt
Reactions: Biteme
NMelkaholic
NMelkaholic
89
241
New Mexico
Had a lil time this weekend to get a few things done....
Installed some seals on the doors to try and help with the dust roll in...
Mounted up the 3' whip lights ( not wired yet) They will only be used when running around in the mesa where there are no trees... that's why I ran them up higher then the roof. When I go huntin, I can remove them quickly
And got a material list of what I need to build the double bow holder....
20210130 122946
20210130 124734
20210130 130556
20210130 130815
20210130 135220
Bigred48
Bigred48
49
39
Peoria Arizona
View attachment 252134View attachment 252135View attachment 252136View attachment 252137View attachment 252138
Awesome machine. What door seal did you use and are the glued? Thinking of doing same.
Reactions: Biteme and ChadD
NMelkaholic
NMelkaholic
89
241
New Mexico
Thanx!!
I first cleaned the door areas with soap and water, then wiped the areas with IPA and let dry..
I used the adhesive promoter ( for better results)
I used this seal for the front doors ( one package is enough for both front doors)
And I used this seal for the back doors ( 1 package did both rear doors.)
It came out really good!! I have not had a chance to test it out yet, but I am sure it will be 100% better then it was!!
Bigred48
Bigred48
49
39
Peoria Arizona
Thanx!!
Thanks NM! Very nice rig.
Reactions: ChadD
WagginTail
WagginTail
1,476
5,457
SC
Nice set up. Have you tried out them shocks yet?
Reactions: ChadD
