P500 "I have questions" thread
The Green Goat
The Green Goat
2,251
16,618
Ohio
So, I've got a million random questions on my mind as I'm trying to plan out mods for this thing (while simultaneously avoiding doing any actual work today). Rather than make a seperate thread for each one, I figured I'd start my own random question thread. Feel free to add to it should you have a question that doesn't necessarily warrant a whole thread.
I'll start:
-Are the front and rear hubs parallel with each other; i.e. is the front wider/narrower than the rear? If not, by how much?
The Green Goat
The Green Goat
2,251
16,618
Ohio
Do you (anyone) suppose the Moose or MFG Supply 2" receiver plate will fit the p52 the same as it does the p5?
The Green Goat
The Green Goat
2,251
16,618
Ohio
Can you run an AGM Aux battery with a SLA primary on the same charge circuit with a Blue Sea Mini Add-a-Battery or does it have to be another SLA?
182,101
You can run an AGM, deep cycle or lithium ion for that matter. You're just going to get different rates of charge and discharge when in parallel. I passed on the isolator and just ran two like batteries in parallel, basically a bigger bank of power. I don't run accessories without the engine running and in the event I do and drain the batteries, I carry a little LI jump pack. Cheaper and less involved than all that isolator and stinger mess. JMO
The Green Goat
The Green Goat
2,251
16,618
Ohio
Regarding: Viper Elite Wide spool winches - 3500-6000lb.
Is there any difference in the physical size/form factor/mounting holes in the various winches or is the difference all internal?
Reactions: J80
hallic
hallic
320
1,795
Central MN
I think it's just different spec motors, but it says the 6k is a smidge bigger? Bolt hole patterns are all the same tho.
Motoalliance web page for the viper elite
  • Dimensions:
    • • Elite 4000 - 15 x 4 1/2 x 4 5/8 inches
    • • Elite 4500 - 15 x 4 1/2 x 4 5/8 inches
    • • Elite 5000 - 15 x 4 1/2 x 4 5/8 inches
    • • Elite 6000 - 15 x 4 1/2 x 4 3/4 inches
Bigtee
Bigtee
556
1,213
Grayson, KY
Are the Viper winches good quality? All I’ve ever dealt with is Warn and Super Winch.
hallic
hallic
320
1,795
Central MN
I've only ever had 2 winches, and old Superwinch lt3000 I got back in 2012 to put on my Rubicon, and my current Viper elite 6k widespool on the p5. Had the Viper since July.
Thing is a beast, only had to use it for a couple hard pulls so far, but it works great, I like it. Hands down, better than the old superwinch, but I think the "LT" was their budget model, plus quite a few years have gone by since then, so I dunno what kind of improvements they're gotten to on newer winches.
Much higher power draw at full load compared to the superwinch, but I factored that into my setup, even though I don't have everything going yet. 2nd battery, larger/shorter cable runs etc.
Reactions: SALTYone
The Green Goat
The Green Goat
2,251
16,618
Ohio
What mount?
Mudder
Mudder
NTC Ambassador of Walls
11,691
88,485
What mount?
Strongmade front bumper here. Good if driving through brush. Seems like is should fit a P520 as it uses u bolts to front. Really like the upper bar as a hand hold in the mud winching.
. EB917C0A 82E1 464E B667 1831A5FD166D
hallic
hallic
320
1,795
Central MN
Currently just using the cheapest winch mount I could find. I'm still undecided on which bumper to get, EMP VS strongmade. I like that the Strongmade is full width of the machine, looks like the EMP stops at the edge of the lights.
BUT, I like that the EMP's top bar thingy sticks out further then the winch itself, which I guess only really matters if I'm gonna go tree bashing or something. I'll probably end up getting the strongmade, once I make up my mind.
Mudder
Mudder
11,691
88,485
Strongmade upper bar is welded, EMP is bolt on. I can attest to the Strongmade hitting a tree hard, no damage. Have an EMP on my Ace, had fitment and bolt issues. Had to deform plastic tray to fit. Really like the style of both vs tube bumpers.
FED4F251 1558 4DAC A5D9 4D13C2EA854206C3BA05 DF54 48CA 8D41 718A20A39745
