Does anyone know if there is a free, ignition switched positive wire, in the P520 wiring harness. I was going to use it for my auxiliary fuse block relay so that the auxiliary block is only powered through the battery when the ignition is on.
Quick and easy KEY ON Accessory power source for your Honda Pioneer. PLUG-N-PLAY No Splicing of wires. No Tapping of wires. 3ft lead easily reaches anywhere under the hood. This kit plugs inline with OEM harness and provides a 12v positive lead. Use this Key-On Accessory wire to run the...
