I am at about 120 miles and the service wrench has lit up. I was wondering what this initial Honda service should include and how much it should cost. Thanks.
How many hours are on it? I’d suggest taking it to the 20hr mark.. it’s 20 hours or 100 miles.I am at about 120 miles and the service wrench has lit up. I was wondering what this initial Honda service should include and how much it should cost. Thanks.
Had a dealer do my first service. They said the valves were within spec. Wish i had done it myself and saved the $.I going to be honest with you guys, most dealers aren't adjusting valves on first services. It's a real time consuming job on the P1K. I highly doubt there out of adjustment on this engine since it's shim under bucket adjusters.
Just my 2 cents.
I was going to bring this up and say that if they adjusted them, that probably wasn't a bad price...but...I going to be honest with you guys, most dealers aren't adjusting valves on first services. It's a real time consuming job on the P1K. I highly doubt there out of adjustment on this engine since it's shim under bucket adjusters.
Just my 2 cents.
...as @JTW said, I'd almost have to see them doing it to believe it. This is why outside of an expensive warranty repair, i do my own work. Always.Valves were half the reason I had them do the first service on mine.. ($175).. I'm pretty sure it’s valves (or maybe valve ball???) making a rattling sound on mine when it’s high RPM and under load. They we’re supposed to check mine but I’m pretty sure they just listened to it and didn’t actual pull the cover to check.
Mine had a small oil leak at the drain plug when i got it home. Guess they didn't replace the aluminum washer. I lost a lot of faith in that dealership after the first service.Had a dealer do my first service. They said the valves were within spec. Wish i had done it myself and saved the $.
Local dealer told me my first service will be around $450. I said no it wont because I'll be doing myself. Thats crazy to just change the oil, check the floods and adjust the valves.
Part of he b**** of it is I can’t pinpoint it... I need to be under the seat at high rpm. When I let off the throttle is goes away. It reminds me of a zip tie on a drive shaft but only under loadIve gotten this a few times on a really good uphill run. Sounded to me like a drivetrain (maybe diffs or just a noisy trans).
Yes, it created a small puddle over a few weeks.Sure it was leaking and not just residual from the change. We always use new washers and wash the underside before pickup.
