P1000 Internal Gear Reduction not saving clutches
Status
Not open for further replies.
265,332
Just seen where a guy who installed the internal gear reductions just burnt his clutch up again.
Screenshot 20170115 095129
Not sure how big of tires he is running but I just don't believe these machines were made for extreme mudding that some people use them for. Especially with 30"+ tall tires.
I have only run the 28" x10" x 14" and have went through 2 clutches, a right rear axle and a left front axle. I don't even get into mud unless absolutely necessary. My point being, I wouldn't recommend throwing a ton of $$$ I to the P1K and expect it to do something it wasn't designed for with tires 30%+ bigger than OEM. It just isn't going to hold up, these machines weigh so much more than an ATV the stresses put on the drive train is going to let something give up the ghost.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
man... 2 clutches AND 2 axles... it's a good thing you don't do anything "too extreme"... no telling what would break!lol :rolleyes:
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I seen that post as well. He runs 32s or 34s. I don't plan on running anything bigger than what I have now. The fact that you've suffered similar damage with smaller tires suggests to me there's a reliability problem. From a company known for reliability.
Ridem32
Ridem32
938
848
Terry
Hate to hear that about his clutches. But if I was not happy with the PK1000 I would go with the 700 not a 500. Why go from the largest to the smallest? JMO
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Excellent question. Sorry to say but if I ever give up on the p1k, I'll have to consider swapping brands. Not gonna give up that power now that I've gotten used to it.
319,548
Imo something needs to be done.if you can't ride in mud then you shouldn't be plowing either and it's a utility vehicle it should at least plow. Again reguadless of how someone is riding or the conditions set forth it shouldn't have any problems for awhile it's a Honda none of the others do. You should be able to get in and run through the gears without a worry but that's my opinion
66,209
I plow with mine. No problem. Yet. That crazy mud riding will kill anything. Especially the peanut butter mud. And of course they are all trying to outdo each other.
319,548
That is true but the mud is a very small percentage of what's been taking the clutches out.
AKRider
AKRider
1,402
3,224
Palmer, Alaska
I was just thinking about your machine. You've went through a couple of sets of clutches and you don't do a lot of mud play, right?
265,332
The first clutch repair I have no idea what actually did it at 160 miles. The second was after 1000 miles and near the end 10 hrs of a 12 hr ride in Tackett Creek which also got the front axle.
I've learned my lesson figuring this machine out. I'm going to a 2017 1000-5 in Blue for the family and swapping my P500 for a 2017 1000-3 LE for my trail riding. Not doing any lifts, maybe go to true 27 x9 Roctane XD on front and 27x11 Roctane XD on rears. I almost never drag as it is losing 2" of ground clearance won't be that much different.
319,548
He was a little zealous pushing the igr and precision products but seemed like a good dude. Hopefully he wasn't abandoning ship lol.
If people drive them the same way as prior then it's got to help some
Reactions: AKRider
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Total agreement. Letting someone drive your rig shouldn't include a 30 minute tutorial on what to do or not do. It should be jump in and go. I love my 1000 and don't see myself abandoning it any time soon. But I'm very disappointed in what's been happening to so many machines out there. Doesn't matter if it's "designed" for it or not. My Neon motor sure wasn't made for a turbo either but it ran over 70k miles at 15# of boost.
66,209
I think non aggressive tires helps the clutch. Yesterday running through the snow. It's obvious compare to my buddies wildcat with his ripsaws. When the going got tough my tensor regulators would spin but zero hopping or chatter just cuts like a pizza cutter. Where the ripsaws bounced and hopped alot. That's got to be hard on the clutch. At least it's something to consider when purchasing future tires. Get them spinning a little gets the clutch fully engaged. Also. I've not been stuck yet with "street/desert" tires. And I've tried.
PioneerPete
PioneerPete
1,496
3,516
Chattanooga, TN
Are you expecting the 2017 clutches to be more reliable?
Reactions: Windrock1000
Status
