P1000 Is it possible to tighten shock spring load on FOX Shocks while on machine?
SuperDutyJohn
SuperDutyJohn
254
437
Vero Beach, FL
Title says it, is it humanly possible to tighten the FOX shock pre-load collars while still mounted to the machine? Maybe getting spring compressors and using a chisel?
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
Yes, but I found it much easier and faster to do with the shocks off.
A good dousing with aeroKroil makes adjusting the suckers easier
Neohio
Neohio
Beast of the East
14,587
73,812
Painesville Ohio
Order a proper spanner wrench, clean the bodies well, like above, use a lube to help resist galling while adjusting.
CLEAN spotless threads are vital!
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I found it was a lot easier to pull the wheel off then the top shock mount loose. It gives you a lot more room to work.
Reactions: JTW
Yup.. I leave the bottom attached and just pull the top. Works like a charm.
