![SuperDutyJohn](/data/avatars/m/12/12147.jpg?1543369186)
Title says it, is it humanly possible to tighten the FOX shock pre-load collars while still mounted to the machine? Maybe getting spring compressors and using a chisel?
Yup.. I leave the bottom attached and just pull the top. Works like a charm.I found it was a lot easier to pull the wheel off then the top shock mount loose. It gives you a lot more room to work.
