P500 Jump starter
Chadmwallis
46
24
Is it safe to use any jump starter. Harbor freight has a lead acid jump starter or a smaller lithium ion. Pros and cons of each?
208,029
Lead heavier, Ion lighter, I would think voltage and amps would come into play
Chadmwallis
46
24
Yes, would like to go with the lithium ion but have no idea if it's safe to use or not.
160,066
This is what I carry. Bestek Lithium Ion.
Bestek
Reactions: Dp5hunter
Hawk53
Hawk53
465
591
Alberta Canada
I have a NOCO lithium Ion . It works well for a boost.
Chadmwallis
46
24
Thanks guys. Would any lithium ion jump starter be safe?
Hawk53
Hawk53
465
591
Alberta Canada
When say say 'be safe " what are you referring too. You still have to use proper boosting precautions even if polarity protectors are built into the boost pack.
Chadmwallis
46
24
Basically by safe is being harmful to the machine. What I'm asking is what should I look for in a battery jumper.
Hawk53
Hawk53
465
591
Alberta Canada
12 volt DC battery
bigbore
bigbore
218
269
Go with the lighter unit, any of those jump starters is going to start a P500. The only consideration is, do you want it to back up your car too? Then peak amps is going to be a consideration.
Chadmwallis
46
24
Ok thanks. What is the max peak amps I should go with.
bigbore
bigbore
218
269
I've jump started my sierra several times with mine, 600 amps.
Mine has a lot of features I liked also, I looked at a lot of them. Wish the case was a different color but it won't be seen much hopefully. It got mostly good reviews.
Hawk53
Hawk53
465
591
Alberta Canada
Weighs 1 pound. Have boosted my pickup with it no problem. USB charging . Has a USB out put also.
