P1000 Key on power harness for Winch
Scamih
168
434
Marshall Illinois
I’ve got vapor Max winch and power on cable coming in today. I’m curious how I hook this up. Any advice or pictures.
63,972
Key on power harness is the correct description
Plugs into the back of the accessory plug. The back of the cigarette socket.
Access it best from passenger wheel well. Look for silver ring holding it on. Unplug and plug it right in repluging the factory harness also.
Scamih
168
434
Marshall Illinois
Ok , so when I’m done I’ll have a red wire to run to my switch and another male end plug for another accessory? Do you have to take fender well off or can you get to it without doing that ? Does anyone have a picture of Viper max winch mounted to a pioneer 1000.
BrotherNov
121
273
Springfield, IL
I ran my key on power harness to a bus bar. Lots of uses for key on power.
BrotherNov
121
273
Springfield, IL
JimmyA
JimmyA
1,644
5,504
Northeast texas
JimmyA
JimmyA
1,644
5,504
Northeast texas
Is there a splitter to use there as, I already have the harness for the Back up Light?
Russ989
Russ989
22,588
146,743
Did you order a specific bus bar or any generic bud bar.
You’re not going to be running everything off this buss bar, it’s suited for powering your switches, you don’t need much to do that.
Russ989
Russ989
22,588
146,743
No splitter, if you’re running a switch for reverse lights you will need to power it from a buss bar or wire it directly if that’s your only switch.
