I’ve got vapor Max winch and power on cable coming in today. I’m curious how I hook this up. Any advice or pictures.
Key on power harness is the correct descriptionI’ve got vapor Max winch and power on cable coming in today. I’m curious how I hook this up. Any advice or pictures.
Plugs into the back of the accessory plug. The back of the cigarette socket.Key on power harness is the correct description
Ok , so when I’m done I’ll have a red wire to run to my switch and another male end plug for another accessory? Do you have to take fender well off or can you get to it without doing that ? Does anyone have a picture of Viper max winch mounted to a pioneer 1000.Plugs into the back of the accessory plug. The back of the cigarette socket.
Access it best from passenger wheel well. Look for silver ring holding it on. Unplug and plug it right in repluging the factory harness also.
Did you order a specific bus bar or any generic bud bar.I ran my key on power harness to a bus bar. Lots of uses for key on power.
Good info!I ordered this one. I like it, but I'm sure there's lots of good options.
Amazon.com: Mofeez Bus Bar -3x1/4” Post,10x#8 Screw Terminal Power Distribution Block with Ring Terminals(Single-Red): Electronics
Amazon.com: Mofeez Bus Bar -3x1/4” Post,10x#8 Screw Terminal Power Distribution Block with Ring Terminals(Single-Red): Electronicswww.amazon.com
Is there a splitter to use there as, I already have the harness for the Back up Light?Plugs into the back of the accessory plug. The back of the cigarette socket.
You’re not going to be running everything off this buss bar, it’s suited for powering your switches, you don’t need much to do that.Did you order a specific bus bar or any generic bud bar.
No splitter, if you’re running a switch for reverse lights you will need to power it from a buss bar or wire it directly if that’s your only switch.Is there a splitter to use there as, I already have the harness for the Back up Light?
