Kolpin Universal IRS 2" Receiver Hitch
feetpiece
feetpiece
Hi all! I finally have a question I couldn't find an answer to via the search function:
Has anyone seen or toyed with the idea of buying one of these? Would it be worth the hassle or should I stick with a standard 2" adapter/coupler?
X001 Y001
64,288
Never see that, But it would raise the hitch to a better level. Almost looks like it might fit with a little modification.
feetpiece
feetpiece
Ideally (for me), I'd like a reinforced plate like this that I could integrate a Bison Rear Bumper with. I'm going to have to find a decent Fab shop locally and report back.
Code54
Code54
583
626
Hurricane West Virginia
Was thinking of tying in the rear rack to the rear bumper for added strength so a 2" hitch could be added?
Reactions: feetpiece
feetpiece
feetpiece
Thats my take on it. I'm not set on a design to have fabbed into a Baja cage but I'd prefer to have it mounted to a bumper rather than the cargo rack.
I dug out a couple of Pelican 1630's leftover from my last deployment and they almost fit perfectly:
20150517 091158
Code54
Code54
583
626
Those pelican cases are top quality and you won't have to worry about getting any water in thats for sure!
Reactions: ohanacreek
That's high quality trunk space. Those things are near indestructible.
I have a 1690 I procured when some demo equipment went out of service and several other sizes I've collected over the years for various other uses from camera equipment to dive gear.
feetpiece
feetpiece
I found the following pics on another forum and really like the idea/set-up:
New20bumper204 zps0byy8cmm New20bumper209 zpspxlvjfol New20bumper207 zpsifumc9p8
The trick will be finding a Fab Shop locally that can do something similar for a reasonable price.
Code54
Code54
583
626
That is sort of what I was thinking of building but I also want to tie it into the rear rack so the bumper has some extra support
sam3006
sam3006
144
411
Damascus, AR
If you tie it into the rear rack and the frame you'll take the shocks out of the equation.
Code54
Code54
583
626
I think it is already all tied together. The rack mounts to the frame and the hitch is part of the frame. Thinking the shock moves between the frame and the "A" arm/wheel assembly. The pivot point being the A arms.
sam3006
sam3006
144
411
Damascus, AR
Yep, you're right, I wasn't picturing it right in my head there for a minute.
