I’ll be using a iPad to look at gps hunting maps as well as a monitor for my scanner! I’m looking at options and would appreciate any lessons learned you have acquired mounting your tablets! Thanks folks!! David
View attachment 292105View attachment 292106View attachment 292107
I've got a couple different setups in 2 machines. I also have the bar clamp for the ram mount like the guy above. Just in case I wanna run with the tablet In my line of sight when I'm by myself. I also ran the spring mount like he has above. I switch to the arkon mount because I slung my 8 inch tablet out of the spring loaded mount a couple of times. But that was really extreme trails and hitting obstacles harder than I probably should have. I broke a ball on a ram mount If that tells you anything. The ram mounts in my dash have a metal backing instead of just the screws through the plastic.LockVise™ Locking Drill Base Tablet Mount with Key Lock for E-Log
Introducing the TAB5METKL Universal Locking Tablet Mount - Ideal for securing tablets in vehicles. Stay safe and hands-free!www.arkon.com
Mine had a case also. I'm talking extreme conditions when it came out. I gave the holder to my buddy and he has never had the same tablet set up come out but he doesn't ride the really rough trails.My tablet stays put with the Otterbox Defender case on it. It wedges into the mount.
I found using the 1-1/2" C size ram mounts for the Ipad were much more stable than the 1" B size. Of course they are more money, but that kind of fits right in with Honda SxS obsession anyway......I mounted an IPad in the center of my upper roll cage using Ram mount components. It has worked well. Also used those components to mount a pair of Schumacher trucker fans in front corners of the roll cage. I'd post some pictures, but I'm on the road and wont be back home to the shop until mid September.
I used the same setup on mine, but located it above the steering wheel. Having the tablet mounted high cuts down on the glare on those bright sunny days here in Arizona.Ram mount system.
Mine is in a otterbox also. Works great and protects the tablet really well.Mine had a case also. I'm talking extreme conditions when it came out. I gave the holder to my buddy and he has never had the same tablet set up come out but he doesn't ride the really rough trails.
You guys using otterboxes - how are you mounting them to the RAM mounts? I would like a better case than the soft-style one I'm running.
[/Ram Mount Flex Adhesive Base with... Ram Mount Flex Adhesive Base with 1-Inch Ball : Amazon.ca: Electronics
I cleaned with alcohol and it stuck really well. So far so good.I've been thinking that RAM needs to come out with an adhesive base, didn't know that one was out...
I'd like to see a much larger adhesive base, though - something rectangular in phone or tablet size. I'd be worried about that 2.5" base coming undone over time.
